How do you remove the drum of the back breaks on a 1995 1.3i starlet not a import
also do you need to bleed them afterward as mine are well worn haven't been replace in a long time and i have cover a lot of miles and my handbreak is adjust to the last
Thank you
Thank you
Should be the same for your car :p
http://www.tercelreference.com/articles/re...conversion.html
Bleeding them would only do them good so why not? :p
