if you are out in the rine and you are geting spray by a lorry it will be fine lol the heat from the turbo is unreal it will
just end up in to condensation if that...if you put your car under water then it will matter lol
thats why your best off putting the air filter in the engine bay, with a nice cold air feed... if you look at the stock air feed on an N/A to the air box, there is almost a "U" bend to prevent the water even getting to the filter...
