Will A Standard 4efe Driveshaft Fit My 4efte Providing The Spline Count Is The Same?
Take your old drive shaft with you if you can and put them up to each other and look for differences i think they are the same as the gearboxes are interchangeable dont see why the driveshaft arn't
Im guessing it will do but im not certain.
Might be worth PM'ing someone who has dropped a 4EFTE into their 4EFE car. I thought the engine went straight in and the gearbox matched up to the 4EFE driveshafts but someone will be able to confirm.
Jason :thumbsup:
as long as the spline count is the same i think it fits. i have my 4efe shafts on my fte engine. think they slightly thinner but there are people running over 200bhp with them so should be ok. dunno if abs and non abs may affect it tho.
