Raz Posted January 31, 2010 Posted January 31, 2010 Ok i got a service comming up, i got spark plugs filter etc. Which oil should i use. It has to be MobilI got my eyes on Mobil Super S. Is there any other good Mobil oil out there? Quote
Lee_EP82 Posted January 31, 2010 Posted January 31, 2010 I use 10w40 Mobil Super S and is fine. Quote
paul. Posted January 31, 2010 Posted January 31, 2010 Me2 ^^^^use engine flush 2 just in case you didnt know Quote
Raz Posted January 31, 2010 Author Posted January 31, 2010 Engine Flush Oo? Why MUST i use that? Quote
paul. Posted January 31, 2010 Posted January 31, 2010 Engine Flush Oo? Why MUST i use that?i always use it in any car. just helps clean out the engine form dirt,gudge, etcalso breaks the old oil coming out down a bit,handier.just up to user prefernce Quote
Raz Posted January 31, 2010 Author Posted January 31, 2010 So i find this? http://www.halfords.com/webapp/wcs/stores/...tegoryId_165750ORhttp://www.halfords.com/webapp/wcs/stores/...tegoryId_165750What is the procedure in using it lol :S Quote
paul. Posted January 31, 2010 Posted January 31, 2010 So i find this? http://www.halfords.com/webapp/wcs/stores/...tegoryId_165750ORhttp://www.halfords.com/webapp/wcs/stores/...tegoryId_165750What is the procedure in using it lol :Syep both will work, i would use the top one.very simple. when you are doing the service pull the car up to garage or wherever you are working on itopen the oil cap on rocker cover and pour full contents of can in and let car idle for 10 - 15 mins. THEN drain the old oil out etc.job done.DO NOT drive on engine flsh. put it in and change oil . Quote
Raz Posted February 6, 2010 Author Posted February 6, 2010 Ok goign to service it nowI got Mobil Super S but is semi-synthetic fine? We've allways used fully syn 10w40 is fine but semi syn? Is that ok.Tell me quick please lol Quote
Raz Posted February 6, 2010 Author Posted February 6, 2010 after doing research i came to a conclusion that semi syn is better Quote
Bean Posted February 6, 2010 Posted February 6, 2010 the past few changes ive done i have used mobil super s 10-40 semi synthetic its got a fiver off at the moment in halfords Quote
Georgie Posted February 6, 2010 Posted February 6, 2010 contact opie oils and ask for tim tell him your spec millege and what you use your car for track, motorway driving etc or join the TB developments forum and pop your spec in the Oil advice and recommendation and he will email you back tanitei entered this for mine Make:ToyotaModel:starlet glanzaYear:96Engine size/type:1.3ltr turbochargedmiles:50,000 oddAny mods:stage 2, full system exhaust,induction,hybrid turbo,large front mount intercooler,boost pressure raised etcType of use: mainly road use short journeys occasional motorway use and also road/track/drag strip, occasionaly aswellAdditional info (max oil temps, current oil used......) semi syntheticWhat do you want a recommendation for? Engine, Gearbox etc? both please his recomendation wasHi GeorgieGo for a good 5w-40 in the enginehttp://www.opieoils....-656-5w-40.aspxGo for the Silkolene Pro S, Millers CFS, Motul 300V, Redline or Gulf Competition.For the gearbox, I'd go for the Silkolene Syn 5 or Motul Gear 300.http://www.opieoils....673-75w-90.aspxCheersTim i rang him and i had the millers engine oil and motul gearbox oil, heres the link he is very helpfull http://www.tbdevelopments.com/forum/viewto...48&start=15 Quote
addz Posted February 6, 2010 Posted February 6, 2010 I use 10/40w mobil super sI despise oil flush liquids. Just run a little fresh oil down to kick out the old Quote
garo Posted March 8, 2010 Posted March 8, 2010 I use Silkolean Pro S 5W-40 Fully Synthetic, a bit more expensive butdefinetly worth it. As its fully synthetic it can withstand higher temps and stress addingprotection to the engine. Quote
5T4R7ET N/A Posted March 9, 2010 Posted March 9, 2010 Mobil semi synth- super S is the one to go for. halfords doing it for 19.99 last time i checked, thats worth it.if i ever use engine flush i use FORTE. I believe they are 1 of the best at at these types of things.i dont use it for every service though, dont need to really. every 25-30k if serviced regularly at 5-6kengine flush is only used at idle for 20-30 mins, never drive with engine flush!!! read the instructions and you be finehope that helps Quote
Carl. Posted March 9, 2010 Posted March 9, 2010 ive recently serviced mine using 10w40 mobil magnatec. was going to go for super s cause its good for high temp protection associated with turbo charged engines... but i mainly use my car to get to and from work and barely boost at all during week so was thinking about the cold starts (where i believe 70% of engine wear occurs) lol anyway the oil does the following:Offers 4 times better wear protection than ordinary oils from start upProvides critical engine protection during start and warm-up periodsOil clings to the engines surface like a magnet providing constant protection even when the engine is switched off Quote
