chriswoodfto Posted February 25, 2010 Posted February 25, 2010 allright guys, right, normally it boosts to 0.84 bar, today it will only get to 0.79 bar, set my apexi to see if it was dropping, it gets to 0.79 then it starts dropping. any ideas? ive been searching for a while and found a few bits on the question but no difinitive answer to my problem.info. cars running fine,there is no smoke from the turbo. read it could be the seal.\so any other ideas? possible leak? if so whats the most likley place for it to be leaking from?also is it ok to drive with this happening? just to get to work and back no hamering. Quote
micky boy Posted February 25, 2010 Posted February 25, 2010 Hello chris, are you useing the stock actuator? if so shot the fucker in the bin get you self a Hks actuator. Quote
chriswoodfto Posted February 25, 2010 Author Posted February 25, 2010 ahh, i was mena put that to stop that answer so quickly, its a hks one mate. Quote
lukEp Posted February 25, 2010 Posted February 25, 2010 weird i lost abit of boost 2days ago but today its back. Quote
chriswoodfto Posted February 25, 2010 Author Posted February 25, 2010 not yet, only discovered it driving home 2night. its just quite hard to check a leak when air is see thorugh,lol. ive seen how to build that leak tester thing on utube but i dont have the time at the mo. just wondered if anyone had a answer, or someone it had happend to. ill have a gud look tuesday when i get chance, any other ideas tho? Quote
chriswoodfto Posted February 25, 2010 Author Posted February 25, 2010 i was wondering if it had anything to with the snow, i know that sounds stupid, but last time it snowed i had the problem with it feeling like it was driving thru glue, and wouldnt boost proply at all. int end it was water down spark plug hole. Quote
chriswoodfto Posted February 26, 2010 Author Posted February 26, 2010 right this morning on the way to work, it boosted to 0.8 bar, held it till it got to about 6.900rpm then it started to drop off, only by 0.02 down to 0.78. it usually boosts to 0.84 tho. any more ideas? still sound like a leak? checked the turbo again and no smoke. Quote
Glanza_cl Posted February 26, 2010 Posted February 26, 2010 well the natural boost curve of a turbo will drop slightly towards the limiter... and 0.02 of a bar is nothing lol. you might have a very slight leak somewhere so just go over all the vac lines and pipes which could potentially be loosing pressure. but really that lower drop is most likely natural turbo loss/ warmer weather (it's only a tiny ct9 remember lol)with the snow thing you mentioned... that could be water getting in/near the plugs causing possibly some hesitation. have you noticed any miss fire at all in the snowy weather? Quote
DavidAshton Posted February 26, 2010 Posted February 26, 2010 Weather, its warmed up, less dense air, less boost. Quote
chriswoodfto Posted February 26, 2010 Author Posted February 26, 2010 not really a miss fire yet, but last time it snowed it took maybe 5days to proply get donw in the hole, then it misfired like a bitch, its either snowed or rained here for ages so ill get the plugs out tuesday and check out the hole. glad its not serious, didnt think it would be as the cars been perfect since i bought it. Quote
micky boy Posted February 26, 2010 Posted February 26, 2010 Weather, its warmed up, less dense air, less boost.^^This lad know's what he's talkeing about Quote
chriswoodfto Posted February 26, 2010 Author Posted February 26, 2010 lol. cheers guys, u off to that yorkshire meet micky? if so could you bring your son ive got a rocker cover he can polish for me seeing as tho he did such a good job on yours.lol. Quote
micky boy Posted February 26, 2010 Posted February 26, 2010 Ha ha lol no mate i dont think i will be going my cars in bits at the min just puting a FMIC on and i need my Apexi power fc mapping.If my son has some spare time after fitting my FMIC lol i'll ask him to polish your rocker cover lol Quote
chriswoodfto Posted February 26, 2010 Author Posted February 26, 2010 quality,lol. more worky less playey. Quote
