B11G KY Posted March 5, 2010 Posted March 5, 2010 I want to run 1 Bar on my ct9... i want to use go with a HKS FCD and AFPR Combo What AFPR would u all recomened and how easy is it to install and set up?i have the following suporting modsGot:Cat BackDecatManiRex TimcHks BovTo buy:Hks ActuatorEBCBoost GaugeAnd of Corse FCD & AFPR Quote
WallaceGlanza Posted March 7, 2010 Posted March 7, 2010 They all do the same thing but it would be better to get a good brand that you can rely on as it's obviously not good if it breaks!They're easy to fit but you'll need it set up on a rolling road to ensure the fuelling is ok. Quote
madmax_926 Posted March 7, 2010 Posted March 7, 2010 They all do the same thing but it would be better to get a good brand that you can rely on as it's obviously not good if it breaks!They're easy to fit but you'll need it set up on a rolling road to ensure the fuelling is ok.someone explain this bump shit to me cause i aint got clu bump Quote
WallaceGlanza Posted March 7, 2010 Posted March 7, 2010 someone explain this bump shit to me cause i aint got clu bumpBump just means to bump up the topic to put it at the top of the forum so somebody will see it and answer your question. Quote
BlackRocket Posted March 16, 2010 Posted March 16, 2010 I'm going to do this later this year just for a bit of extra power before I sell up!I've got a Sard RRFPR and HKS FCDSard/ Fuel Lab/ FSE - all FPR's tend to do the same but you get what you pay for usually so spend a bit more for a better quality one is my adviceSteve Quote
B11G KY Posted March 16, 2010 Author Posted March 16, 2010 What about instilation are they hard to fit i looked for a How 2 thread but no luck secondly when it is fitted what should it be set to ? Quote
Guest Enzo Posted March 23, 2010 Posted March 23, 2010 i would stray away from a hks fcd and hunt out a more stable jam fcc the jam works differentlyboth are pretty similar with wiring but i cant advise on actual instillation as ive never fitted one before.in all honesty i would not stray down this route, bumping up the fual pressure feed the extra air is sort of primitave if you know what i mean. it does have its advantages of being cheaperan emanage or jap ecu would be my recomendation Quote
B11G KY Posted March 23, 2010 Author Posted March 23, 2010 Thx enzo your right i gotta stop cutting corners lol and open up the purse strings lol Quote
