  • Replies 105
  • Created
  • Last Reply
Top Posters In This Topic
Nice update mate when are you planing to fit the e-management?...what will you be doing with the JAM ECU?
Also im not sure if you already know but if you are running alot of boost with the stock manifold in place you can kill your engine. Because the third runner is restrictive people say dont run anymore than 0.8bar on the stack manifold....I hope that bit of info has help mate B)
dont know jet mate can i'm planning of going forged first
and i heart about the 3rd runner of the manifold but that was after i run at those psi and i am planning to port that out now with my fmic i can't pass 1bar B)
im probably going to sell my Jam ECU cuz i don't need it any more
and tnx Mate for the tip
Can someone help or explain to me what this is (ECU) stock?
someone told mi its a fuel cut defendor
and they told me maybe the ecu is chip so i open it
everything seems to like factory made
if that's the case can some one explain to me how come i can exceed 15 psi cause all the other glanza's here reach 15 and blow there engine the previos owner ran 18 psi every day i reach 22 and 25 and still going strong and no fuel cut no boost cut nothing one thing i got is a hks actuator
pls explain
tnx mate's
car looks awesome with those wheels and that front lip suits it well. definatly looks like a standard ecu there though bud :lol:
tnx mate
but if it's a standart ecu how come i can reach so high boost with out blow my engine then ?
some honda guy told me with the honda ecu the can change the map in the ecu and you wont noticed it till someone shop you the chip that it's been change or not
so i'm clueless
Hello Qglanz
That is the stock ecu with a fuel cut defender (FCD)
The JAM FCD is an electronic device that overrides the high boost fuel cut function of your vehicle's ECU. It broadens the area of high boost which will allow the vehicle to obtain much higher boost settings, giving a increase in performance as well as faster response.
But if its not set up right, then it can kill your engine......Hope that help mate
So Micky Boy
your tell me the JAM FCD will take off my boost cut also and let me boost till 22, 25 psi
and how come my car is rich then ?
tnx mate for the explaination
Yep it will let you boost to what ever the stock map sensor will let you.. whitch is 1.2bar
As for your car running rich has your car got a fuel pressure regulator at all?
nope i don't have a FPR cause they told me a have a chipped ecu which it has the fuel presure raised and i don't need it
now that i'm going to emu i trying to figure out what is the ecu so i can put a valeu to sell it i came across all this
i reach 1.25 bar on it, on the road
so now that i'm going emu i need a FPR also ?
tnx mate
Hmmm im very surprised its doesn't have an adjustable fuel pressure regulator if i was you i wouldnt boost anymore than 0.8bar 12psi untill you get the emu fitted and mapped...
And yes you will be better off geting your self a adjustable fuel pressure regulator when you get the EMU fitted so the mapper can set the fuel pressure to suit your mods i would also advise you to uprated your fuel pump when you get the emu fitted and mapped
Hope that helps mate
Tnx mate
your very helpfull
i was as suprised as you cause all the other glanza or starlet here after 15 psi they blown there engine and i was wonder why i can reached those psi and feel lots of power and the car drive better when im above 15 psi but never didn't trust ecu so now i limit to 8 psi i think and now i can reach til 12 or 14 psi it think with my FMIC so i think its safe there
and tnx for the help mate
very helpfull of you
if there's more people pls give your advice
i wanna reach the 200hp mark on the stock turbo
Not a problem mate im more than happy to help
If you get all your mods on your car now befor you fit the emu then the mapper will get the best results.
This is what i think you will need to get your car to 200bhp boosting @1bar on the stock ct9
EMU
FMIC
HKS actuator/boost controller set @1bar 1.1bar anymore than that on the stock ct9.. it wont last long
exhaust system
exhaust manifold
Decat
air filter relocated to the front bumper A/C removed
uprated fuel pump
And that should do you, obviously it depens on how good the mapper is to what power you will get.
hope that helps mate
Wel i have
full 2.5" exhaust
FMIC
EMU
and hks actuator just have to set it to 1.1 bar
i'm planning to port the stock manifold and get a Decat (the currency really place a roll that everything get very expensive here to order)
i have a FPR just have to get it from a friend
and have to order in a fuel pomp
and about removing my A/C not going to happen i live in the caribean and it 365 days a year hot so no can do!
and my FMIC pass just in front of the turbo so i thinking some other way to put a air filter
can i reach it on a stock bottom ?
cause i'm planning to go forged also to be sure
:lol: i forgot you live in the caribean you lucky man.
Well you could get something like this then you could keep the A/C and get that extra bit of power also :p
Here's the link
http://cgi.ebay.co.uk/38MM-PRO-Stainless-S...=item2306012256
Im not sure what you mean by stock bottom? If i am right i think you mean bottom end of the engine if so i would say get that forged/rebuilt aswell.....I've heard of people running a stock head on a forged engine and it was fine
stcok bottom i mean with stock piston and rod
hey tnx for the link mate i'm gonna order that it's really cool tnx :lol:
yea im planning of going forged cauze you may never know better safe then sorry
and do you think i can reach that hp if i just port the exhaust manifold and get a decat
my currency to your money is
2.95 guilder is 1 pound i think so it's really expensive :p
Yeah i would of thort so porting the manifold is just as good as any aftermarket mani....But it dose still depend on the mapper no how much bhp you will get.
yea i know i wanna reach 200 but i got a 185 or 190 is ok
about there i can reach a 13 sec on the strick with some good slicks
so with that i would be happy :lol:
tnx for the advice mate
really helpfull
tnx Mate
one or two question
when i install the emu can i take the fcd off?
and when can i put a oil catch tank on a 4efte ?
Hello buddy
Yeeh when you get the emu installed you dont need the fcd
As for useing a oil catch tank you can use one now if you wish :rolleyes: I've never botherd useing one to be honets i use a breather and its never give me any problems.
ok ok
i was just wondering
tnx mate
i when to the dragstrip last weekend
i run 16.038 best time but had a 60' of 2.7 or so lots of wheel spin and that's on the 17's
i finish at 89.5mhp hahahaha
