ste91 Posted March 16, 2010 Posted March 16, 2010 The brakes on my EP91 are quite shit, there's a fair bit of travel in the pedal before anything happens, and then when they do start to work it's not very good, and at high speed there's a fair bit of vibration.Another thing is the tracking/alignment is a bit shit but I'm going to get that done soon.So what's causing the vibration and pedal travel? I'm guessing the vibration is either warped discs or the fact that the tracking is shit, OR worn bushes.The pedal travel I'm assuming is because the brakes need bleeding.The pads are fine, look fairly new actually. The discs on the other hand look pretty shitty. Quote
Carl. Posted March 16, 2010 Posted March 16, 2010 The brakes on my EP91 are quite shit, there's a fair bit of travel in the pedal before anything happens, and then when they do start to work it's not very good, and at high speed there's a fair bit of vibration.Another thing is the tracking/alignment is a bit shit but I'm going to get that done soon.So what's causing the vibration and pedal travel? I'm guessing the vibration is either warped discs or the fact that the tracking is shit, OR worn bushes.The pedal travel I'm assuming is because the brakes need bleeding.The pads are fine, look fairly new actually. The discs on the other hand look pretty shitty.sounds like your rotors (discs) are shagged with vibration or could be other things like wheel bearings or even balancing of wheels or uneven tyre wear and so on but if the rotors look f**ked its probably them.as for travel of pedal its most likely they need bleeding as you said. have you checked level of brake fluid? Quote
ecksjay Posted March 16, 2010 Posted March 16, 2010 warped discs prob, easily done with even moderate braking. Quote
Carl. Posted March 16, 2010 Posted March 16, 2010 warped discs prob, easily done with even moderate braking.yeh. can be done easily by keeping your foot on the brakes when their hot and your stood Quote
ste91 Posted March 16, 2010 Author Posted March 16, 2010 Think I'll just get some new discs and have the alignment done then, should I see an improvement in braking with new discs or will it just get rid of the vibration?It's nothing to do with the wheels as I had two new tyres on the front last week. Could possibly be wheel bearings now you mention it. Quote
ste91 Posted March 16, 2010 Author Posted March 16, 2010 Can anyone verify that these discs will fit an early EP91 Sportif, as I'm sure they had slightly smaller discs to the later ones?http://cgi.ebay.co.uk/Front-Brake-Discs-TO...=item48393e9ca1 Quote
Nick@TD.co.uk Posted March 19, 2010 Posted March 19, 2010 Drop us a Message or Call and we will sort you out with anything you need at very competitive prices also we offer fitting services if required.Does sound like the discs are warped if you have a vibration through the steering.Look forward to hearing backKind Regards, Nick JonesTuning Developments LTDWorkshop Landline - 01925 822266www.TuningDevelopments.co.ukTuningDevelopments@Hotmail.com Quote
Keri-WMS Posted March 19, 2010 Posted March 19, 2010 Does the pedal pulse, and does it get worse the harder you brake - like especially downhill? Quote
ste91 Posted March 19, 2010 Author Posted March 19, 2010 Haven't noticed the pedal "pulsing" but the braking does get worse yes, at low speed there is very little vibration, but at high speed it's quite bad. The pedal travel is bad too, gives you little confidence even in slow moving traffic if you get a bit close to the car infront.I'm hoping changing the discs and bleeding/changing the brake fluid will sort it out, but I have barely any money at the moment. The car is driveable but it's just shit having to allow such a long braking distance. Quote
Keri-WMS Posted March 19, 2010 Posted March 19, 2010 Haven't noticed the pedal "pulsing" but the braking does get worse yes, at low speed there is very little vibration, but at high speed it's quite bad. The pedal travel is bad too, gives you little confidence even in slow moving traffic if you get a bit close to the car infront.I'm hoping changing the discs and bleeding/changing the brake fluid will sort it out, but I have barely any money at the moment. The car is driveable but it's just shit having to allow such a long braking distance.I'm betting you have sticking sliders on the calipers as well.......check them out when you fit the new discs / pads! Quote
