Hey guys, I'm just wondering how to remove the windows in my starlet (5 door)?
Any help is appreciated, thanks in advance.
Shafz.
i dont have a 5 door 91
but am sure you will just pull the door cards off they will just be on plastic clips, remove the handle maybe a little pannle covering a screw???
pull up the window seal undo the bolts olding the motors in and brackets then you glass should come out
get someone to help you to hold the glass and let them pull it out when you undo the last bolt of the bracket
A hammer or a brick would work quite well.
not that well !
you will spend hours picking up bits of glass
and risk lots of cuts
door glass is easily done by removing door panels and undoing a few screws
the rear screen needs work as its bonded in
I found using a piece of bicycle brake wire gently see saw'd through the bonding worked, needs 2 people, 1 inside and 1 outside
