when i was driving yesterday, i was accelerating to take over on the duals nd when i changed gear the was like a popping noise from the exhaust, it only popped once but its done it a couple of times since ive put the rolla mani on.
anybody know what this is please?
is that a good or bad thing?
sounds good but didnt know wether it was causing any damage
wont cause a problem mate just little bit of unburnt fuel and heat in the exhaust !!!
you might want to have your timing checked as this can cause what your describing, if your timing is out you could be loosing out on power!!!!
my gt used to pop and spit flames a lot when i modded it and raised the boost was awesome
impressive in an n/a though :) sure its nothing major dude
