theminiguru Posted March 31, 2010 Posted March 31, 2010 im looking to install a mechanical boost gauge, which vacuum hose do i connect the t-piece to? map sensor? pics would be appreciated..cheersPM ME Quote
lukEp Posted March 31, 2010 Posted March 31, 2010 the vac pipe that goes from the mani to fuel pressure regulator Quote
Lawsy Posted March 31, 2010 Posted March 31, 2010 im looking to install a mechanical boost gauge, which vacuum hose do i connect the t-piece to? map sensor? pics would be appreciated..cheersPM METheres a few hoses you can tap into on the manifold, but i just t-pieced into the dumpvalve/blow of valve vacuum hose. easy to get to. Quote
Michel_M Posted March 31, 2010 Posted March 31, 2010 Maybe someone should do a really short tutorial on installing a boost gauge, cause I always see a lot of the same questions popping up. I think it's also a basic mod that everyone does first. (I'm too lazy though and my car already had one installed actually ) Quote
Lawsy Posted March 31, 2010 Posted March 31, 2010 Maybe someone should do a really short tutorial on installing a boost gauge, cause I always see a lot of the same questions popping up. I think it's also a basic mod that everyone does first. (I'm too lazy though and my car already had one installed actually )ill try get some pics up 2moro if a got time, and show where to tap into. Its really easy to get it through the firewall/bulkhead aswell Quote
Lawsy Posted April 3, 2010 Posted April 3, 2010 im looking to install a mechanical boost gauge, which vacuum hose do i connect the t-piece to? map sensor? pics would be appreciated..cheersPM MEHey mate just some pics that may help?1. Pic of BOV vacuum hose with the t-piece and guage hose connected">2. Shows a close up where to t-piece the vacuum line from the guage into the vacuum line for the Bov">3. Shows the Vacuum line going into the firewall through the gromet. If look up inside the drivers footwell you can pull the hose through into the inside the car and up into the dash.">Hope this helps, if not ill try to explain more Quote
Michel_M Posted April 3, 2010 Posted April 3, 2010 ^Maybe a mod or something can move this to the EP Wiki? Nice write-up. Quote
Lawsy Posted April 3, 2010 Posted April 3, 2010 ^Maybe a mod or something can move this to the EP Wiki? Nice write-up. Thanks mate, simple when u know how Quote
Raz Posted April 4, 2010 Posted April 4, 2010 what about the electronic. Whats the best and simplest way and location to connect that? Quote
