chriswoodfto Posted April 13, 2010 Share Posted April 13, 2010 having decided that the glanza brakes are abit shit really ive managed to source some gt4 st185 twin piston front calipers/hangers/pads and discs for the amazing price of 50quid!!! quality. i did a brake upgrade on my old colt, to fto twin pistons up front, it stoped dead as soon as you pushed the brake. cannot wait top get them fitted!!!just a quick question now, can i still use my glanza brake line? i cant afford to stick braided lines on right at the mo im afraid. ill get round to that in a few weeks. Quote Link to post Share on other sites
Steve GT Posted April 13, 2010 Share Posted April 13, 2010 50 quid?? thats a stealget a pic up of them big boys Quote Link to post Share on other sites
chriswoodfto Posted April 13, 2010 Author Share Posted April 13, 2010 will do, soon as they arrive and ive stripped and painted them up. i ordered some aluminium/chrome aerosol the other day to do my rocker cover and a few other bits, you reckon i should do the calipers that color or keep them red? yea 50quid was a right bargain. kennedy kindly told me of a guy who had the same setup for sale, 350quid he wanted. so i rekons ive done well good!!! dont think the breakers knew how rare them brakes are. i posted on the celica owners club and even they couldnt find me any of the st 185. Quote Link to post Share on other sites
Lee_EP82 Posted April 13, 2010 Share Posted April 13, 2010 ST185 brake disks are 5 stud iirc.You will need prius/corrolla disks or drill some holes to match up the 4 stud hub. Quote Link to post Share on other sites
chriswoodfto Posted April 13, 2010 Author Share Posted April 13, 2010 yea i know Lee. im just gona re-drill the holes to 4x100. nice and easy job. Quote Link to post Share on other sites
WallaceGlanza Posted April 13, 2010 Share Posted April 13, 2010 ST185 brake disks are 5 stud iirc.You will need prius/corrolla disks or drill some holes to match up the 4 stud hub.Yeah, I was going to say - you do realise those won't just bolt straight on? Quote Link to post Share on other sites
chriswoodfto Posted April 13, 2010 Author Share Posted April 13, 2010 yup. ive spent the last 2weeks reading enzo's brake upgrade post so i know everythign i need to know. and then trying to find the right bloody caliper. there like rocking horse shit. Quote Link to post Share on other sites
WallaceGlanza Posted April 13, 2010 Share Posted April 13, 2010 Ah good stuff, well that is a nice cheap decent upgrade then, let us know how they feel once on. Quote Link to post Share on other sites
chriswoodfto Posted April 13, 2010 Author Share Posted April 13, 2010 will do buddy, hopefully as impressive as when i fitted the fto gear to my colt. anyone know about wether the brake line will fit from my glanza? i dont have to get a celica one do i. Quote Link to post Share on other sites
lukEp Posted April 13, 2010 Share Posted April 13, 2010 brake banjo's are usually the same size from my understanding just replace the copper washers they should be fine. Quote Link to post Share on other sites
chriswoodfto Posted April 13, 2010 Author Share Posted April 13, 2010 sweet cheers guys. Quote Link to post Share on other sites
the quiet achiever Posted April 13, 2010 Share Posted April 13, 2010 hi i`m in the process of using the ST185 calipers in a brake up-grade i couldn`t find corolla ones . i foud that the ST185 disc suggested in DIY & spacer suugested to not be suitiable (the disc heights/offset is wrong &spacer sets the wheel to hang on the wheel studs not good me thinks ) i went looking for a disc that is bgger in dia &with the right offset found the RDA679 to be the one that matched my measurements ( std 238mm up-grade 260mm the max size that will fit inside the caliper &wheel without mods to mount). only thing needed was an adapter to match disc 66mm to starlet 55mm not a spacer so disc fits in original position on hub . i haven`t fitted any thing yet so info is measurements only do a trial fit &you will see what i encountered( it doesnt just work the way the guide says ) the std disc is too deep it need to be less by the thicknees of the spacer i`m going to post a detailed DIY guide as soon as i have fitted them on &they work satisfatorly but so far i reckon i`m onthe right track . june /july @ this point just some thing i found so far in my up -grade hope this doesn`t put you off lyle Quote Link to post Share on other sites
chriswoodfto Posted April 13, 2010 Author Share Posted April 13, 2010 cool. adapter to fit? 66mm to 55mm? were about is it your talking about? if the spacer between the hub and inside of the brake disc, it shudnt put any more load on the wheel studs shud it? as its just spacing the disc to the middle of the caliper? the discs offset will still sit on the hub tightly just 3mm further away? surely 3mm wont cause a massive load problem? ill just have to pop the new caliper and hanger on when i get them and check its all ok. i thought the write up enzo did hed actually fitted them with the set up suggested and im guessing he got it to work? ive pm's him but hes really busy so as soon as ive spokent to him ill let you know what he suggests too. Quote Link to post Share on other sites
Lee_EP82 Posted April 13, 2010 Share Posted April 13, 2010 I got 3mm spacers but they wont fit under the disk so need machining down lol Quote Link to post Share on other sites
Danturbo4311 Posted April 13, 2010 Share Posted April 13, 2010 I run these brakes on mine & paid double that price for em, thats a bargain, they work well, & they will fit the standard brake lines, I used a set of 4 stud prius discs vented & drilled cost me £70 new but it saves on drilling out some 5 studs to make them fit as i dont really like the idea of drilling a disc although others have done it with no problems, I also used a 5mm spacer behind the hub to centralise the disc in the caliper & the standard wheel lugs are fine to use I've used mine for about 9months now, no problems. Im running 1.6 bar of boost on a gt28 & a 50 shot of nitrous & still stop fine with these. Quote Link to post Share on other sites
the quiet achiever Posted April 13, 2010 Share Posted April 13, 2010 cool. adapter to fit? 66mm to 55mm? were about is it your talking about? if the spacer between the hub and inside of the brake disc, it shudnt put any more load on the wheel studs shud it? as its just spacing the disc to the middle of the caliper? the discs offset will still sit on the hub tightly just 3mm further away? surely 3mm wont cause a massive load problem? ill just have to pop the new caliper and hanger on when i get them and check its all ok. i thought the write up enzo did hed actually fitted them with the set up suggested and im guessing he got it to work? ive pm's him but hes really busy so as soon as ive spokent to him ill let you know what he suggests too.hi the adapter is just to size the disc to fit the hub dia centre hole . the disc i suggested should fit straight on without the need for spacers to centre disc in to the caliper( i fouhd the std celica didn`t do this )i also wanted to avoid having the wheels sit only on the studs i sat the std disc inside the celica caliper when fitted &moved it around until it was central in the caliper the difference was exactly the thickness of spacer thus i reduced the offset/ height of disc by this thus saving the need for a spacer &the wheels sitting om studs only i hope this clarifies my reasoning you will seewhat i mean once you do a trial fit with the std disc i found the celica &the starlet to have the same offset any way i forgot to mention this was all done with parts avail in australia in case the import UK parts are different lyle Quote Link to post Share on other sites
chriswoodfto Posted April 14, 2010 Author Share Posted April 14, 2010 ahhh, cool. cheers guys. i was a little worried for a miute that i just bought summit that wont gona work!!!lol. ive ordered some 3mm spacers like enzos post states so ill just get a grinding stone and take a little off the outside edge. Ill try it with the spacer first as i dont have the money for new discs at the mo, ive got some really good condition st185 discs for a tenner so ill drill them and use them for now, then when they need changing ill get the discs T.Q.A recomended. the fto upgrade i did used 10mm washers to space the brake disc out so i reckon even the 3mm spacer will be alot safer.lol. Quote Link to post Share on other sites
the quiet achiever Posted April 14, 2010 Share Posted April 14, 2010 ahhh, cool. cheers guys. i was a little worried for a miute that i just bought summit that wont gona work!!!lol. ive ordered some 3mm spacers like enzos post states so ill just get a grinding stone and take a little off the outside edge. Ill try it with the spacer first as i dont have the money for new discs at the mo, ive got some really good condition st185 discs for a tenner so ill drill them and use them for now, then when they need changing ill get the discs T.Q.A recomended. the fto upgrade i did used 10mm washers to space the brake disc out so i reckon even the 3mm spacer will be alot safer.lol.hi just remember every mm you space it takes whee&disc futher away from the hub &then they are sitting onthe wheel studs only not what iwould say is a safe way to have a wheel mounted on a car but see how you go . lyle Quote Link to post Share on other sites
lukEp Posted April 14, 2010 Share Posted April 14, 2010 i think lyle is talking about a spigot ring to locate the brake disc on the hub like what you get with aftermarket alloys plus when you put a spacer behind the disk it will space everything out so you wheels might catch on the arch if im wrong let me know but i dont think i am. Quote Link to post Share on other sites
the quiet achiever Posted April 14, 2010 Share Posted April 14, 2010 i think lyle is talking about a spigot ring to locate the brake disc on the hub like what you get with aftermarket alloys plus when you put a spacer behind the disk it will space everything out so you wheels might catch on the arch if im wrong let me know but i dont think i am. hi that is right . i didn`t want any extra load on the wheels studs that is why i searched for a spacerless alternative . just so happens the disc i found required a spigot ring instead lyle Quote Link to post Share on other sites
chriswoodfto Posted April 14, 2010 Author Share Posted April 14, 2010 cool. if the spacer is a solid metal disc though with the centre hole bored out obveously, and just the correct size hole for the wheel bolt to go through, surely the weight wouldnt be an issue, as it would just act as extenshon on the offset of the brake disc? I know exactly what your trying to explain though mate, If i had some spare cash to get the disc you mentioned id go for that one but just till i can ill have a go with the spacer and st185 disc. Quote Link to post Share on other sites
