sure they will fit mate. everythin needed to do the swap is there. im not sure what the difference between abs and non abs discs are tho but should still fit .
pretty sure they will go on matey the only thing abs has different is on the driveshaft there are some teeth type things and the hub has a hole for the abs sensor as for the disks i think they are all the same mate
As above - they will fit with no issue, the sensors are mounted on the hub and signal read off of the CV joint, it is a separate entity to the discs
  • 2 months later...
  • 3 months later...
all starlet front pads are the same, the only different is that the glanza has slighty bigger discs and as a result will have a slighty different carrier to space the caliper out alittle.
Jack
