silverglanza Posted May 2, 2010 Share Posted May 2, 2010 right guys some of u may no my bro sold me a apexi boost controler avcr old school one nick a td fitted it for me it gave up the ghost on test run sooo i got a manual one works perfect but i recently had got a hdi boost controler off ebay 120pound from japan all it needs is a postive and negitive to work then vac hose and plum the solinoid in aswell soooo done all that theres power going to the unit and going down the line to the solinoid there continunity on the solinoid lines aswell but when u go for a run in the car it boosts at 9psi turn it up nothing happens and u can turn it all the way up still nothing same if u turn it all the way down thort i may of had the plumbing wrong but switched the pipes round still nothing anyone shed any light on this should i just send it back for a refund or get another one? surely its brand new it cant be buggerd the apexi one i had off my bro cost me 130 this cost me 120 and im no better off Quote Link to post Share on other sites
WallaceGlanza Posted May 2, 2010 Share Posted May 2, 2010 Did people not advise you that the HDI one's are crap when you asked about them? Quote Link to post Share on other sites
silverglanza Posted May 2, 2010 Author Share Posted May 2, 2010 from what i recall i posted up but no1 repleyed thort hdi were supposed to be ok like the coolers are Quote Link to post Share on other sites
Glanza_cl Posted May 2, 2010 Share Posted May 2, 2010 as Wallace said... they suck balls! shame you wasted your money.just think if you had spent a little more in the very beginning you could have not had all these problems, hence the saying 'do it cheap, do it twice'mate save and get a decent one. gizzmo do some very affordable ones and they work very well... or you can pick up a second hand blitz for pretty much nothing nowadays.see if you can get your money back, then put it towards a good one. Quote Link to post Share on other sites
Lee_EP82 Posted May 2, 2010 Share Posted May 2, 2010 Gizzmo you should have saved the extra and brought so easy to set up and its some good crack. Quote Link to post Share on other sites
WallaceGlanza Posted May 2, 2010 Share Posted May 2, 2010 from what i recall i posted up but no1 repleyed thort hdi were supposed to be ok like the coolers arehttp://www.ukstarletclub.com/forums/index....c=29491&hl=Most people that have used these boost controllers have ended upgetting rid of them as they just don't work.Unfortunately as suggested you would be best getting rid of it for one that's known to work well. Quote Link to post Share on other sites
ToyotaTech15 Posted May 2, 2010 Share Posted May 2, 2010 for the HDI boost controller to work you need to get a consant feed of OVER 12 volts or it just won't power up atol.Just need to check wires until you get the right power. As if it's just over 12v and you join another component in it will cause a resistance an you will get maybe high 11's which just isn't enoughHope this helpsGary Quote Link to post Share on other sites
silverglanza Posted May 2, 2010 Author Share Posted May 2, 2010 so what u saying i need to just connect it directly to the battery ? to make it work when the car is on its like 14v? Quote Link to post Share on other sites
lukEp Posted May 2, 2010 Share Posted May 2, 2010 i had this problem it was the vac line it need to be plumbed up to the fuel pressure reg vac line and make sure its not being pinched anywhere or it wont work I've had mine in for 6month with no problem at all Quote Link to post Share on other sites
