ade1964 Posted May 14, 2010 Posted May 14, 2010 Now I know this is going to sound really stupid, and should be really easy for you guys, but :-there are 2 pipes coming out of the bottom of the turbo, one has a steel tube that bolts to the oil filter area, where does the other one go to, it points directly towards the floor, and is about 19mm diameter.ThanksAde Quote
ToyotaTech15 Posted May 14, 2010 Posted May 14, 2010 Itl be the oil feed and return for the turbo,Your right one bolts to the oil filter housing and the other one should have a 90 degree rubber hose to the sump for the oil returnIf it points to the ground then you must be missing the hose Gary Quote
ade1964 Posted May 14, 2010 Author Posted May 14, 2010 But there's nothing on the sump to put a pipe toThanks Quote
ToyotaTech15 Posted May 14, 2010 Posted May 14, 2010 If it's a turbo sump from a 4efte it should have a union welded into the sump.Have you used an 4efe or 5efe sump by any chance?What are you actually building?Gary Quote
ade1964 Posted May 14, 2010 Author Posted May 14, 2010 I have just realized why there might be no sump pipe, when I bought the engine, there was no sump, I purchased one from ebay, wonder whether I got a standard starlet, and not the turbo one.Is that all this pipe does, return oil to the sump?Thanks again Quote
ade1964 Posted May 14, 2010 Author Posted May 14, 2010 So would I be OK to weld a return pipe into the sump? Quote
Russleh Posted May 14, 2010 Posted May 14, 2010 yeh its basically just a hole in the sump as far as im aware. Quote
rob_bower Posted May 14, 2010 Posted May 14, 2010 have you just bought a sump or did you buy the oil pick to other wise the sump wouldn't fit! Quote
ade1964 Posted May 15, 2010 Author Posted May 15, 2010 have you just bought a sump or did you buy the oil pick to other wise the sump wouldn't fit!The sump fits ok with the pick up I've got, will just weld in return pipe. Quote
ade1964 Posted May 15, 2010 Author Posted May 15, 2010 has anyone got a photo so I know where to weld new one in.Thanks Quote
