GlanzaJim Posted May 25, 2010 Posted May 25, 2010 I've put a tub of exhaust paste on my backbox join bit will it be hard to get it off? Quote
ToyotaTech15 Posted May 25, 2010 Posted May 25, 2010 What do you mean?You've repaired a leak with it and you will need it off at a later date?Usualy it just goes hard and it can be chipped off with a screw driver or small punch depending on what kind of paste it is.Gary Quote
GlanzaJim Posted May 25, 2010 Author Posted May 25, 2010 What do you mean?You've repaired a leak with it and you will need it off at a later date?Usualy it just goes hard and it can be chipped off with a screw driver or small punch depending on what kind of paste it is.Garyokay well i brought a tte yaris back box yes it does fit but was blowing a tad, so i brought some fire stuff ( i dont know the name) i coverd it in it round the bracket and the back box, but when i come to selling or get bored of it i would like to change to a normal box again so would it be hard or like you said just get screw driver and chip it off?thankyou Quote
drongo boi Posted May 25, 2010 Posted May 25, 2010 it should just chip off pal, i did the same with my old 106 and it just chipped off mite end up with abit left on but no harm done lol Quote
ToyotaTech15 Posted May 25, 2010 Posted May 25, 2010 Ok, yeh then a screwdriver or small chisel/punch will have it off, it will more than likely come in little bits but its not very strongGary Quote
GlanzaJim Posted May 25, 2010 Author Posted May 25, 2010 Ok, yeh then a screwdriver or small chisel/punch will have it off, it will more than likely come in little bits but its not very strongGaryahh thankyou to both, its because i got hump it was blowing so i just used hole tub and its everywhere, i also got a bracket welded onto the exhaust and it was to small so its on cable ties atm, im not going to keep its too rubbish, i was just worrying about this paste incase i wont be able to get it of lol, i will just have to get a powerflow one!thanks again Jamie. Quote
Keri-WMS Posted May 26, 2010 Posted May 26, 2010 I've been messing about and built an exhaust for the MR2 from scratch out of:Jet engine stainless pipe (seeeexy and thin) eBay stainless U-bendCitroen BX Mi16 silencer! (light)Saved like 10kg and a heap of cash! Quote
