Shaun Posted October 26, 2006 Share Posted October 26, 2006 how hatrd is it to use the bottem end of a 5efe in my starlet turbo what pistons do they use and would you need to upgrade the crank and rods Quote Link to post Share on other sites
SiCaln Posted October 26, 2006 Share Posted October 26, 2006 well as far as that goes u use 5e rods with the 4e pistons u have but its not as easy as that go and look on tgtt theres a lot to it ask Rick Quote Link to post Share on other sites
StarletRick Posted October 26, 2006 Share Posted October 26, 2006 its really not as simple as you may think mate. you cant use the ct9 manifold with the 5e. or the ct9 for that matter, its too small. therefore you need a new downpipe. answer to thatr is a new turbo kit. theres a grand right there. then you need new rods. 5e rods are not good enough. thats another 500 quid. new turbo will probably require new pistons for the higher boost. thats 350 quid. you need to have the block notched for the pistons. another 100 quid. you also need the 4e flywheel re drilled to fit the 5e as the crank is different. more money. im working on one now. and i have to say, the ammount of money i am spending is obscene. i wish i hadnt started. unless you are aiming at HUGE power. id steer clear of the 5e. 4e is a good block. and is capable of making alot of power. Quote Link to post Share on other sites
SiCaln Posted October 26, 2006 Share Posted October 26, 2006 and there u have it Quote Link to post Share on other sites
Nanglebadger Posted October 26, 2006 Share Posted October 26, 2006 And there u have it, Rick has spoken! I'd often contemplated turboin a 5e, sounds like a LOT of work tbh, lookin forward to seein your progress Rick mate.Phil. Quote Link to post Share on other sites
Shaun Posted October 26, 2006 Author Share Posted October 26, 2006 thats ok it just me car is going to be of the road for a year and was going to spennd shit loads on it lol Quote Link to post Share on other sites
Sparky Posted October 26, 2006 Share Posted October 26, 2006 Whys that shaun mate???What you gonna be motoring around in for a year??? Quote Link to post Share on other sites
Guest Enzo Posted October 26, 2006 Share Posted October 26, 2006 ok i dont think it will cost an arm and a leg to anyone that is compitent and capable of building an engin like you shaun.i intend on building mine from scratch myself.and it all depends on what results your trying to achieve,if you start with a 5efhe engine you dont need the rods as the rods on this engine are way thicker then the ftea ct9b can stil be used(what i intend on using if i dont have a hybrid)theres a good chance you wont need to hone the bores aswell,usa a larger(212 as oposed to 200) 5e flye wheel clutch and presure plate,i do understand that a 4e is capable of making enuf power but with me i plan on gettin as close to 210-20 bhp the easiest way with the small turboand a 5e with 5EFHE rods along with a heavily brethed on head should help me do this on a ct9 with no lag and power straight away for an every day streetable setupwell see how it pans out, Quote Link to post Share on other sites
Shaun Posted October 26, 2006 Author Share Posted October 26, 2006 sweet cheers mate dont no what car to get mate lol Quote Link to post Share on other sites
klyfax Posted October 29, 2006 Share Posted October 29, 2006 Use a 5E-FHE engine, 4e-fte pistons, 2 cylinderhead packings or a HKS 2mm packing. Grinded Camshafts. A turbo to fit 240 HP and a other exhaust manifold. And a custom exhaust system. And of course a other ECU.The 5e engine fits on the 4e gearbox. So you just need a other clucht.That will give you 200 HP with 0.9 bar. 13 lps. At least. Remember not to push the engine to the edge, when driving at high speeds, or you pistons wont hold to it.Good look. Quote Link to post Share on other sites
Sparky Posted October 29, 2006 Share Posted October 29, 2006 Shaun said: sweet cheers mate dont no what car to get mate lolGet ya n.a back Or another one Quote Link to post Share on other sites
starlet_king Posted October 29, 2006 Share Posted October 29, 2006 klyfax said: Use a 5E-FHE engine, 4e-fte pistons, 2 cylinderhead packings or a HKS 2mm packing. Grinded Camshafts. A turbo to fit 240 HP and a other exhaust manifold. And a custom exhaust system. And of course a other ECU.The 5e engine fits on the 4e gearbox. So you just need a other clucht.That will give you 200 HP with 0.9 bar. 13 lps. At least. Remember not to push the engine to the edge, when driving at high speeds, or you pistons wont hold to it.Good look.i like the sound of that, seems like a good setup,is this what your running ??? Quote Link to post Share on other sites
klyfax Posted October 30, 2006 Share Posted October 30, 2006 Hehe no I'm after High rpms not high NM. I know a guy that is going for that setup, but if it works? Don't know... Quote Link to post Share on other sites
