Hi guys,
Ive just orderd HKS fuel cut defender, rx7 tmic and a boost controller and Hks adjustable actuator
My engine is standard running the normal ct9 turbo and stanard exhaust system.
Im looking to reach 190 +
What improvments will i be seeing with these ?
cheers guys any help will be muchly appreciated
Think you will need to uprate the manifold and the exhaust at least. Not to sure. My car is standard like yours as well
Stage 1 mods i think
Manifold back exhaust system w/decat
Relocated air filter,
Uprated plugs & leads,
RRFPR
I think with the above you should see about 185bhp at 1 Bar
You'll want some proper management, atleast a piggyback like emanage blue or similar, don't bother with the FCD.
As already mentioned above - full exhaust system, decat, manifold.
Relocate the air filter (not only does this give the air intake a better location but there is quite a significant restriction in the standard intake pipe).
Possibly want to do away with the top mount and go for a FMIC instead.
But you will still struggle to see 190bhp, you might want to consider a hybrid CT9, would be easier and less strain on the turbo itself.
Not quite the figure you're after but Sparky made 185bhp/185ftlb with the usual bolt ons, exhaust system/decat/manifold/air filter/FMIC/etc... tuned on emanage blue.
well put it this way i got about 180 to 190 bhp getting it on the rollers soon
i got
fmic
iridium spark plugs
magnacore leads
full 2 1/4 inch exhaust
mani
decat
air filter relocated
up rated fuel pump
sard fuel pressure reg
boost went up to a bar
hks actuator
greddy e manage blue
probley missed somthing lol
