Josh@TunerLifestyle Posted June 9, 2010 Share Posted June 9, 2010 I've seen these about on the forum but i dont know what they are! are they an ecu? or is it something compleatly diffrent? ino its a noob qurstipn but i wont know unless i ask cheerrs! josh Quote Link to post Share on other sites
lukEp Posted June 9, 2010 Share Posted June 9, 2010 Its a piggyback ecu that is mapable without a computer via a screw with 10 setting, 0 being stock up to 9 and a exhaust temp gauge, it only controls fuel managment not timing, and is very old now but does a good job I'm running 1bar with one and on full beans exhaust temps are 800degrees need a HKS fcd for it to work on anything over stock boost as they are degsined to work togeather. Quote Link to post Share on other sites
Josh@TunerLifestyle Posted June 9, 2010 Author Share Posted June 9, 2010 would it be ok to plug it in and use on my engine with stock parts? as im slowly upgrading bit by bit and I've seen one cheap and could afford it first, and eventualy im looking for about 200bph would this support itcheers josh Quote Link to post Share on other sites
lukEp Posted June 9, 2010 Share Posted June 9, 2010 yeh i had mine pluged in far ages while i got set up just set the thing to 0 (stock fueling) and its like its not there then you can turn it up while ya driving when setting it up just make sure you at least have a exhaust gas gauge and sensor on and working check my build thread i have pictures of mine being fitted.and yes 200bhp is acheveable with the supporting mods the ecu can fuel upto 250bhp on standard injectors after that you need to uprate the injectors Quote Link to post Share on other sites
Josh@TunerLifestyle Posted June 9, 2010 Author Share Posted June 9, 2010 cheers mate verry helpfull what mods do u reccomend with thid? upratwd fuel pump, injectors stuff like that? cheers josh Quote Link to post Share on other sites
lukEp Posted June 9, 2010 Share Posted June 9, 2010 No the ecu its designed to run with the stock fuel system upto 250bhp. Just decat, decent mani or port yours, port wastegate, exhaust system airfilter, boost gauge and wack up the boost and set it up or better still have it setup by a pro on the rollers so he can check ya fueling and they will also be able to give you an estimated flywheel print out too. Quote Link to post Share on other sites
Josh@TunerLifestyle Posted June 9, 2010 Author Share Posted June 9, 2010 that sounds spot on! exactly what im planning guna see if its still for sale and get myself one ok now for a silly question ! can they over fuel and have flames from the exhaust? im a pyromaniac haha cheers for the help bud appreciate it Quote Link to post Share on other sites
lukEp Posted June 9, 2010 Share Posted June 9, 2010 Yeh u can over fuel but easest way side exit or flammer kit Quote Link to post Share on other sites
Russleh Posted June 9, 2010 Share Posted June 9, 2010 im sure if its just the fcon it will only be the big box and the gcc ( bit with the wee screws on it ) is sometimes solt seprerate so just make sure u know what your getting mate. Quote Link to post Share on other sites
Josh@TunerLifestyle Posted June 9, 2010 Author Share Posted June 9, 2010 im sure if its just the fcon it will only be the big box and the gcc ( bit with the wee screws on it ) is sometimes solt seprerate so just make sure u know what your getting mate.cheers mate il keep my eyes open, dont wana get stung! i dont have alot of money so id be fucked!thanks again josh Quote Link to post Share on other sites
Russleh Posted June 9, 2010 Share Posted June 9, 2010 looks like this mate. Quote Link to post Share on other sites
Josh@TunerLifestyle Posted June 9, 2010 Author Share Posted June 9, 2010 thankyou:) everyone is so helpfull i lav it! Quote Link to post Share on other sites
Russleh Posted June 9, 2010 Share Posted June 9, 2010 im sending you a bill so dont worry about thanking me jkn. its cool mate Quote Link to post Share on other sites
lukEp Posted June 9, 2010 Share Posted June 9, 2010 You don't need the gcc for this to work, I never got one with mine, its just fine control of the injector pulse at rpm increments i'm sure the gcc is a add on and i'm looking for one for my system. Quote Link to post Share on other sites
Russleh Posted June 9, 2010 Share Posted June 9, 2010 yeh i just put the pic up so that he knew what he was gettin when he was buyin. think i missunderstood your first reply when ya sayin settin from one up to 9 i thought ya were talkin about the bits on the gcc . my bad. if ya can get bother together tho then thats a wee bonus Quote Link to post Share on other sites
lukEp Posted June 9, 2010 Share Posted June 9, 2010 Yeh deffo if I knew the system woulld of been fine tuneable with a gcc I would have sauced it when I bought the f-con. if he can get them both together and wants to sell me the gcc :) Quote Link to post Share on other sites
