Emma_SR Posted June 27, 2010 Posted June 27, 2010 Jim has given me his spare strut brace for my SR however the fuel filter is in the way. can someone please tell me what needs to be done in order to move the filter so that the brace can be fitter once paintedThanks. Quote
Amjad Posted June 27, 2010 Posted June 27, 2010 Just unbolt the filter from the brackets, and get someone to push it either behind or in front of the strut brace as you try to fit it. The strut brace can be a little awkward if it hasn't been fitted before, you have to put it on the thread a tiny bit equally, and give it taps from a hammer each side 'til it pops on!Hope that helps! Quote
rmsnoel Posted September 24, 2010 Posted September 24, 2010 To update this thread. A fuelfilter bolted to the fuel line unsupported isnt a good idea. Petrol causes fires. If fitting a standard glanza or gt to a n/a simple hammer a dent into the rear of the strutbrace were it meets the top of the fuel filter. This dent wont affect your handling Quote
LukeSR Posted September 24, 2010 Posted September 24, 2010 Or you could just push the filter back whilst someone bolts it Quote
Russleh Posted September 24, 2010 Posted September 24, 2010 pretty much. if its so tight that ya have to squeeze it on then im sure no fires will be had Quote
rmsnoel Posted September 27, 2010 Posted September 27, 2010 Then it vibrates on the strut brace and wears away. I always find that when giving advice online, make it a idiot proof as possible. Emma SR maynot be an idiot but the next person to read this may be a complete idiot There are also 2 types of fuelfilter and one sits alittle higher than the other. You also shouldnt put much stress on your fuel line. Quote
