Matty079 Posted June 28, 2010 Posted June 28, 2010 Just picked up my new rear axle and currently trying to take off the old one. a couple of questions...The braces which go along the side of the car towards the front, how the hell do you undo these bolts? I'm so confused...Also, the handbrake on my new axle has been cut, how do I go about getting my old one onto the new one?Please help! I want my starlet back on the road!! haha Quote
ToyotaTech15 Posted June 28, 2010 Posted June 28, 2010 The trailing arm bolts that are at the front of the axle are just long 17mm headed bolts that go right throught the bushes and go onto a welded nut.The handbrake cables are held on the calipers with a u-clip and a pin that goes on the caliper mechanism. There will be a small r clip on the pin at the very end of the handbrake cable ( caliper end) then just a little further along the cable there is a u- clip that secures the cable to the caliper ,hope this helps Gary Quote
Matty079 Posted June 29, 2010 Author Posted June 29, 2010 The trailing arm bolts that are at the front of the axle are just long 17mm headed bolts that go right throught the bushes and go onto a welded nut.The handbrake cables are held on the calipers with a u-clip and a pin that goes on the caliper mechanism. There will be a small r clip on the pin at the very end of the handbrake cable ( caliper end) then just a little further along the cable there is a u- clip that secures the cable to the caliper ,hope this helps GaryThanks mate, managed to get one of the trailing arm bolts off earlier, wasn't too hard. Just got the other side (haven't tried) and the right hand side bolt just next to the caliper. That one is a bitch, I've soaked it in CRC many times and it's still not budging, i even snapped a spanner on it yesterday. Any idea on how to get that loose? I'm in Australia so some of the stuff that's in the UK may not be available here Also, when I undo that clip, will I have to catch some brake fluid? or... I'm still kind of lost on the brake part Quote
bucketep91 Posted June 29, 2010 Posted June 29, 2010 use a breaker bar to get more purchase on it and ittl come off Quote
Idrees Posted June 29, 2010 Posted June 29, 2010 There will be no fluid leak when you undo that clip as it's just for the handbrake cable. I'd recommend using a blow torch on the nut/bolt you are stuck with. It always works for me, I don't even attempt this sort of work without a blow torch! Quote
Matty079 Posted June 29, 2010 Author Posted June 29, 2010 There will be no fluid leak when you undo that clip as it's just for the handbrake cable. I'd recommend using a blow torch on the nut/bolt you are stuck with. It always works for me, I don't even attempt this sort of work without a blow torch!I've tried to upload pics but unfortunately i've gone over my download limit so it's not letting me On the back of the caliper I've unscrewed 3 screws and managed to get a part of the handbreak cable off (I believe that's what it is) as it has been cut off just as it leaves the axle, there is also a cable that goes from the caliper through the trailing arm and is then cut off around 10 inches out of the trailing arm. How do I disconnect that from the caliper? It looks as though I could get it off if I had access to the inside of the brakes, but I have no idea how to get in there haha. I wish I could get these pics up, it would make things so much easier Quote
