Translated, sort of lol
TOYOTA STARLET GT TURBO.
4E-T517Z TURBO + F-CON V PRO 2.1 VERSION.
Into the second month. Sweet favorite month of the Valentine's Day comes with a colorful car TOYOTA STARLET (EP82) GT TURBO 3 DOOR HATCHBACK arrested for the upgrade with the new paint Author units around. Including turbo. Up strength by You REVTEX effects Garage owner in the area Road Vehicle Tent Suchart Nawamin.
External TOM'S.
Party organized around a MINOR CHANGE the end of this body. Before you change the EP91. The fire front is a sphere. New grille. In addition to color and distinctive. Parts fully decorated with bumper side skirt and rear skirt Adjustable rear tail.
Add the new seat gauge.
More cabin decor. And removing some of the away. The new front seat from RECARO TYPE R SPARCO steering wheel to change the Dashboard as TRD 280 km / h roll bar added each half collapse as four cars after SAFETY21 the center console also decorated with CARBONFIBER. And coaster set with the top row ACCESSORIES Gauge GReddy 6 comes with a soap and a post adjustment of electricity from HKS EVC audio version from HEAD UNIT PIONEER DEH-P4950MP.
Engine 4E-FTE.
Filling in the new box, new
Engine for this car. A gasoline engine turbo code 4A-FTE 1,331 cc 135 hp customize the gut cells. And the pressure was very good and I send exhaust out faster. Camera set with tea intake and exhaust Lift JAM RACING Bureau of Japan. The very small car in the long STARLET size 11.5 mm lift 301 degrees to order special Webcam slide with gear set for the Overseas Lab. Reinforced with steel gasket 1.2 mm Lower add strength to the Blue post from WISECO FORGED PISTON high with the same size. In addition, changing the use of turbo GReddy T517Z with the West Gate of size 38 mm control MINE'S Blue posted 1.5 bar
The ID systems move Inter coolers to the front of bolt EVOLUTION I've with that of valves of the cooling set BLITZ add to oil with Oil Cooler TRUST. And change using an aluminum radiator from GOLPNER the change in fuel injection systems used EVOLITON size of 510 cc pressure control with PRESSURE REGULATOR from HKS pump fuel NISMO parts spark plug replacement is NGK No. 8 upgrade coil ignition is MSD BLASTER SS total control with the box, HKS F-CON 2.1 VERSION mechanics effects REVTEX transmission to manual transmission 5 speed. Accessory Set for SHORT SHIFT and clutch kit from TRD Lightweight Fly Wheel's TODA with the LSD CUSCO 1.5 WAY.
SUSPENSION CUSCO.
Wheels VOLK RACING TE37.
Customize suspension for Traction. And the real everyday comfort with a shock absorber strut adjustment screw of the page CUSCO JURAN shore shore shock after shock and C-pillars bearing CUSCO Brake old four-wheel disc brakes. Six-spoke wheel design of the model VOLK RACING TE37 15 x 7 inch size NITTO NT01 tires size 205/50ZR15.
Thank you a car owner and the owner Garage REVTEX Effect on Road Vehicle Area Tent Suchart Nawamin Tel. 08-1721-5940 and location filming PTT MOTORSPORTS LAND แดนเนรมิต old
http://www.grandprixgroup.com/new/magazine...arlet(4)/08.jpg
''up strength by You REVTEX effects Garage owner in the area Road Vehicle Tent Suchart Nawamin.''
Sounds like its done by a local garage to him, so somewhere in Thailand?
