Dan507 Posted July 10, 2010 Posted July 10, 2010 Just came back from going outside to fit my clear indicator lenses and failed. Undone the bolts ontop of the indicator expcting it to come out, it didn't. moved it around abit more to see if it would come out, it didn't. i gave up.So... i thought i'd have a try at doing my steering wheel. undone one screw, moved onto to another one it undone but will not come out.....then gave up.FML. That is all... Quote
LukeSR Posted July 10, 2010 Posted July 10, 2010 The indicator can be a bitch to get out, needs to be pulled to the wing a bit i think!Also steering wheels can be bitches, esp if its a airbag and your putting non airbag on Quote
ryan lang Posted July 10, 2010 Posted July 10, 2010 lmao ill get some pics up 2moro for you of how to take the steering wheel off mate, i done mine the other day because the numpty who done my dials didnt put it back on straight and i eventually got fed up of it being wnoky so i did somethnig about it lol, fairly simple tbhindicators are pretty much straight forward too mate, you gta twist it toward the wing a bit, then it should pop out enough for you to slide it out, after youve undone the screw 1st tho lolEDIT: make sure the wheels are straight before you take it off/ put it back on Quote
Dan507 Posted July 11, 2010 Author Posted July 11, 2010 Savage! i have only had my streering wheel and boss kit under my bed for two months Quote
ryan lang Posted July 11, 2010 Posted July 11, 2010 lmao, i couldnt tell you how to fit your boss kit mind lmfao, just how to take your old 1 off, is the standard 1 a 4 spoke 1 or the 3 spoke wheel? Quote
ryan lang Posted July 11, 2010 Posted July 11, 2010 ahh thats okay then lol same as mine okay mate ill take it off and take some pics for you to put it back on lmao Quote
Steve GT Posted July 11, 2010 Posted July 11, 2010 indicators can be bitches mate theres a nack to them and steering wheels are even worse lol bit of gentle force i find works everytime Quote
ryan lang Posted July 11, 2010 Posted July 11, 2010 yes but you have to be careful with the steering wheel because of the airbag im off outside to get some pics for you now mate Quote
mk1kurt Posted July 11, 2010 Posted July 11, 2010 two hex screws either side of the steering wheel one is coverd up then the airbag will start too come loose then there should be a few wires unplug them the gently remove the airbag there will be a big nut i the middle of the steering wheel undo it ad the steering wheel will came straight off be careful not to twist the steering wheel when doing this as he new wheel will be on the pisshope that helps you dude BEFORE DOING THAT DISCONNECT THE BATTERY as my mate didn't and his airbag went off in his face kurt Quote
ryan lang Posted July 11, 2010 Posted July 11, 2010 ive got the pics mate il;l edit them with pretty arrows for you now, then post them up Quote
ryan lang Posted July 11, 2010 Posted July 11, 2010 here you go dude, as promisedand a quick note before you sit there forever wondering how long the screws are, none of them come out lol, they loosen but they are held in placeand make sure your wheels are straight before starting alsothis is how it should look/ clip behind the head of the screw once that side is done, go the other side and you should see thisyou mite have to pull down the wiper stalks but because the battery is disconnected nothing will happen and you will be fine lolthen give the centre a wiggle and gentle pull and it should come out like soomake sure you dont pull to hard, because you will have to disconnect the horn wiresget a 19mm socket, with a nice extension for manouvrability and undo the centre nutthen its just a case of pulling the wheel off, but be careful it doesnt fly off and smack you in the face (experience) lolhope this helps dude Quote
ryan lang Posted July 11, 2010 Posted July 11, 2010 they are in my build thread, i pm'd you saying that they are in my build thread lmao Quote
Dan507 Posted July 11, 2010 Author Posted July 11, 2010 thanks Ryan, are the last for pictures suppose to be the same Quote
LukeSR Posted July 11, 2010 Posted July 11, 2010 My steering wheel is nothing like that lol.. Then again it is different Quote
ryan lang Posted July 11, 2010 Posted July 11, 2010 lmao no, they aint lol, did you get it done after? Quote
Dan507 Posted August 1, 2010 Author Posted August 1, 2010 Right i have undone the nut, it wont come off? it did hit the steeing lock? HELP or am i being a pussy Quote
Raz Posted August 1, 2010 Posted August 1, 2010 pull harder! When you get knocked out in the process you know you have succesfully removed the steering wheel when you wake up. Quote
bucketep91 Posted August 1, 2010 Posted August 1, 2010 undo the nut just a little bit (leave it on tho or when you pull the wheel off youll break your nose) then pull hard at the wheel and dont be scared to slap it about a bit it will come off Quote
Dan507 Posted August 1, 2010 Author Posted August 1, 2010 yeah, it off now. almost ht me in the face Now....Dilema 2 neew steering wheel. i bought the custom quick release from night spirit thinking it was the whole thing. i'll upload a pictures in a second. but i think i need a boss kit aswell. Quote
