GT Phayer Posted July 27, 2010 Posted July 27, 2010 can some one show me a picture of how they have mounted the bottom of there civic radiator thanks. Quote
ktl Posted July 27, 2010 Posted July 27, 2010 cables ties mate... holds well enough and doesnt move. just make sure you bracket the top 1 Quote
ktl Posted July 27, 2010 Posted July 27, 2010 you literally get 2 cables ties, put them together, and put it through the bottom of the radiator (the last fin) then wrap around the bottom frame. likewise the other end. so 4 cable ties all together. Quote
GAZ@A&G_TUNING Posted July 27, 2010 Posted July 27, 2010 lave it out!!!!!!!!!!!!!!what ya do lad is when you look down you see the original rad bracket, drill out the spot welds that hold it on, your rad can now sit flush with the front top panel, then get a piece of metal apx 50mm long and apx 20mm wide, dril couple 10-12 mm holes so the civic rad bottom pin's sit into these, then weld of bolt these to the bottom bar, then make a top bracket to secure Quote
rorenapier Posted July 28, 2010 Posted July 28, 2010 Pikey botch job..... you literally get 2 cables ties, put them together, and put it through the bottom of the radiator (the last fin) then wrap around the bottom frame. likewise the other end. so 4 cable ties all together.Or the proper way.....lave it out!!!!!!!!!!!!!!what ya do lad is when you look down you see the original rad bracket, drill out the spot welds that hold it on, your rad can now sit flush with the front top panel, then get a piece of metal apx 50mm long and apx 20mm wide, dril couple 10-12 mm holes so the civic rad bottom pin's sit into these, then weld of bolt these to the bottom bar, then make a top bracket to secureI know which one id rather use. Quote
ktl Posted July 28, 2010 Posted July 28, 2010 lol works for me for the time being and tooks 5minutes.. and is solid!! i dont have a welder also but that was the way i was gonna also do it. ^^ Quote
GT Phayer Posted July 28, 2010 Author Posted July 28, 2010 also has anyone use the standard rad fan housing on there civic rad ? Quote
Stulet-GTT Posted July 28, 2010 Posted July 28, 2010 also has anyone use the standard rad fan housing on there civic rad ?Standered rad fan is to deep, air-con fan work's i think... Quote
