scutch0 Posted November 15, 2006 Posted November 15, 2006 i know this cant be good, but ive noticed a build up of oil around the venting area of my bov...is this a major issue? should i be looking about for a new turbo in the meantime? or is it relitively harmless?the engine doesnt seem to be drinking an abnormal amount of oil either. and theres seems to be no smoke out the exhaust.Rich. Quote
paul w Posted November 15, 2006 Posted November 15, 2006 Is that the standard dump valve in the pic too? looks like it's coming from that and dripping down from there. Quote
scutch0 Posted November 16, 2006 Author Posted November 16, 2006 yeah, i have the standard one still on, but its blocked off.its defo coming from the aftermaket bov as its seaping out of the housing slightly. Quote
NightSpirit Posted November 16, 2006 Posted November 16, 2006 Scutch mate,Do you still run the crank case breather back into the inlet (shit design) or does it go through a catch tank?That could account for some of the oil. Take off the piping to the IC and check how much oil is on the turbo side of the IC.It doesn't look like a lot to me and does the turbo smoke idling? or on boost or lift off? It could be the above.Worst case I'd say is the seals in the turbo, but if they get bad your car will just chuff out smoke for fun. I'd save up for a nice aftermarket blower and I may be wrong here...but the crank breather goes into the stock recirc as standard yes? if that's still attached it could be coming from that unblocked pipe in the pic that drops directly onto your oldschool HKS bov Quote
scutch0 Posted November 16, 2006 Author Posted November 16, 2006 i heard this elsewere too.it may be that.. i'll have to inspect it...it doesnt smoke at all really, not even when giving it a bootfull, i get all the usual condensation and water vapor out the exhaust though.the pipe you see in the pic is blocked off with a bung, so i dont think its coming from there, but yes the crankcase breather is still going into the recirc valve.thanks for the help bud. Quote
Glanza_Ragger Posted November 16, 2006 Posted November 16, 2006 take it for a hard drive, then park up and let it idle for 5 minutes.. see if it chucks out oily blue/white smoke from the exhaust..they can sometimes give out small amounts of oil if you dont run a catch tank, but generally speakin, if theres alot of oil residue inside the intercooler pipework then your turbo seals are probably on there way out...if you find out they are going, i have a brand new set from toyota Quote
scutch0 Posted November 18, 2006 Author Posted November 18, 2006 ive had the intercooler off only a few weeks ago and there was very little oil in there.i'll have to have a look again. Quote
lobotomy Posted November 18, 2006 Posted November 18, 2006 I don't think it's too much of a problem mate -- just keep an eye on things though and run a baffled catch tank. Quote
ecksjay Posted November 19, 2006 Posted November 19, 2006 looks fine mate. my arc bov was the worst culprit for chucking out oil, it just dumped the fumes (which is all it is, the fumes collecting and turning into liquid) straight down onto the rocket cover, which resulted in quite a mess. never used any excess oil though as it was just purely vapour collecting in a little pool of oil.bit of oil in the intercooler is fine too mate, nothing to worry about unless its like, massive amounts, its just excess residue. Quote
scutch0 Posted November 19, 2006 Author Posted November 19, 2006 cool. cheers for that eks. i didnt think it was anything serious.take it for a hard drive, then park up and let it idle for 5 minutes.. see if it chucks out oily blue/white smoke from the exhaust..did this tonight, not even a haze out the exhaust! no smoke/vapor at all. Quote
lobotomy Posted November 19, 2006 Posted November 19, 2006 The reason you take it a long drive is to get rid of any condensation lying in the exhaust... (for those who didn't know)And another tip is to hold a piece of kitchen towel up to the exhaust for a minute -- pull it away and smell it, if it smells like oil you might have a slight problem. If it's got specs of oil uh-oh spaghetti-oh you might have a bigger problem! Quote
Glanza_Ragger Posted November 19, 2006 Posted November 19, 2006 cheers lobotomy forgot to add that sounds just like vapour releasing like ecksjay said then, if its not smoking once its burnt the condensation off .. nothing to worry about, if it makes too much of a mess rich, just invest in a catchcan to keep that bay shiny Quote
scutch0 Posted November 20, 2006 Author Posted November 20, 2006 sweet. nice one.i have noticed i get little black specs over the rear of the car, altho i thought this was the car running rich?is it likely to be oil? Quote
paul w Posted November 20, 2006 Posted November 20, 2006 Specks are probably just a bit of soot from the exhaust that shows up because it's a white car.Dampness on the car in the morning would trap some soot. Quote
Glanza_Ragger Posted November 20, 2006 Posted November 20, 2006 to be honest rich, if it doesnt smoke once warm, i wouldnt worry. my blitz supersound bov vents a bit of oil to the atmosphere (love you greenpeace)ill invest in a catchcan when i can afford it Quote
