  • Replies 221
  • Created
  • Last Reply
Top Posters In This Topic
I had this problem so phoned sparky lmao
Pull the rubber bits away from the headlight just enough so yuo can get a screwdriver inside
Use the screwdriver as i lever
Then get some pliars and grab hold of the thicker bit of the rubber abd pull to one side
You will see the ends on the rubber(bits nearest lamp) start to move
Get the screwdriver and place it underneath the bits that are movibg and simply pop it off
When doing the one near the battery i found it easier to undo the battery and move it a little
Just make sure you remember to put it back
Hows that MJ?
MJ you suck......
As for you Mr Elliott, waking me up asking me how to change your fricking lights, not impressed man :p
Only jokin love ya really , glad i could help :p:p:p
  • 1 month later...
Well its about time i updated this
I havent really done much as i aint really had the money
But.....
I was fed up with the look of the rear end because of the horrible wiperblade that is one there
So....
I changed it! ;)
Before
After
Comments welcome always
