hello everyone much help appriciated,im just wondering on what mods would make me see more power out of a ct9 hybrid?
my mods are-
ct9 hybrid
toytuning actuator
fmic
relocated filter
air con removal
trd leads
ngk irridium plugs
turbo smart dumpvalve
full custom exhaust
race tech cat
zisco mani
hdi boost controller low boost- 0.6 high -1.0
jam fcd
sard rrfpr
super air flow convertor
the car has also been setup on a RR at pd tuning in boldon and made 174hp and 143hp at wheels and was at 0.6 boost,the boost controller was on low boost when it got setup and i forgot to change it to high so i never got to know what it does at 1.0 bar
Throw away the shit FCD/RRFPR and get some proper management, a piggyback like Emanage is what most people seem to go for.
You could also turn the boost up a little.
a piggyback and more boost would see more power.
how can u be hitting fuel cut if u turn it up?
if you mess around with the boost it will mess up your fueling, take it and have it set up properly again
if i turn the boost up a little it hits fuel cut.if i adjust the fcd will it mess up my fuelling??cheers
Don't bother messing with it, buy a piggyback ECU (E-Manage Blue is the easiest option), and have everything done at the same time, get it mapped with the boost turned up a little, you wont have to worry about fuel cut or any other issues. You may need to change the injectors depending on how much boost you want to run. Bear in mind once you start going to higher power levels you will need to uprate other things like the clutch for example...
