ep91_glanza Posted September 5, 2010 Share Posted September 5, 2010 hello everyone much help appriciated,im just wondering on what mods would make me see more power out of a ct9 hybrid?my mods are-ct9 hybridtoytuning actuatorfmicrelocated filterair con removaltrd leadsngk irridium plugsturbo smart dumpvalvefull custom exhaustrace tech catzisco manihdi boost controller low boost- 0.6 high -1.0jam fcdsard rrfprsuper air flow convertorthe car has also been setup on a RR at pd tuning in boldon and made 174hp and 143hp at wheels and was at 0.6 boost,the boost controller was on low boost when it got setup and i forgot to change it to high so i never got to know what it does at 1.0 bar Quote Link to post Share on other sites
ste91 Posted September 5, 2010 Share Posted September 5, 2010 Throw away the shit FCD/RRFPR and get some proper management, a piggyback like Emanage is what most people seem to go for.You could also turn the boost up a little. Quote Link to post Share on other sites
ep91_glanza Posted September 5, 2010 Author Share Posted September 5, 2010 if i turn the boost up a little it hits fuel cut.if i adjust the fcd will it mess up my fuelling??cheers Quote Link to post Share on other sites
bucketep91 Posted September 5, 2010 Share Posted September 5, 2010 a piggyback and more boost would see more power.how can u be hitting fuel cut if u turn it up?if you mess around with the boost it will mess up your fueling, take it and have it set up properly again Quote Link to post Share on other sites
ste91 Posted September 5, 2010 Share Posted September 5, 2010 if i turn the boost up a little it hits fuel cut.if i adjust the fcd will it mess up my fuelling??cheersDon't bother messing with it, buy a piggyback ECU (E-Manage Blue is the easiest option), and have everything done at the same time, get it mapped with the boost turned up a little, you wont have to worry about fuel cut or any other issues. You may need to change the injectors depending on how much boost you want to run. Bear in mind once you start going to higher power levels you will need to uprate other things like the clutch for example... Quote Link to post Share on other sites
