hi,
i wanted to know how hard would it be to turbo a corolla?
would it be easier to turbo the 4efe or to drop a 4efte?
roughly how much would it cost? need it as cheap as possible (bare in mind im a student lol)
many thanks
It would definitely be cheaper just to buy an fte rather than turbo your engine, that's for sure. Not sure on how much it'd cost though, I think someone on TGTT has an fte'd AE101!
thanks bro..
need rough prices though lol..
il have a look on tgtt...
If the blocks are the same (4EFE 4EFTE) would it make easier to swap all the internals, sump, clutch and g/box from the 4EFTE into the 4EFE
found this on AUSC
You have 2 options.
1: 4efte transplant from ep82 GT or glanza V (technically should only be from glanzaV)
2: 4efet (turbo your 4efe stocko engine)
Option 1 should give you 100kW at the fly
Option 2 should give you appx 135kW at the fly
First of all, differences / similarities between the turbo import engine and the stocko Aus engine:
Block is the same
Crank is the same
Cams are very similar, 1mm difference
EP91 fuel pump is stock supra fuel pump, -can support a large demand
No extra oil squirters
Compression ratio from 9.6 - 8.2 (Pistons slightly larger to make this)
4efte gearbox stronger
4efte connecting rods thicker
4efte clutch slightly stronger
4efte oil sump has oil return from turbo
4efte oil pump different
4efte crankpulley (harmonic stabiliser) substantially heavier
4efte drive shafts thicker
4efte supsension slightly different
4efte injectors larger to support boost
That being said, there are 4efe's that have been turbo charged and been running powerfully happy at 15psi for many km's
OPTION 1
Positives with transplant:
Bolt in fit
Fairly cheap
Should get some funky white Glanza V dials
Should be able to sell some parts for money if not needed
Should only be one - two days labour to drop everything
Goes fast
Negatives with transplant:
The engine could be in bad condition, it has happened in the past
Water pump / timing belt / fuel / oil filters / oil should be replaced
Transport of the half cut
Needs EPA tests and engineering to register
Expected Costs:
Half cuts range from $1500-$3500
$500 exhaust (cat, catback, muffler, fitting)
$40 Oil
$16 Spark plugs
$30 Fuel Filter
$7 Oil Filter
$65 Timing belt
$150 Water pump
$1000 labour (maybe cheaper if import is GlanzaV)
Free: EPA test
$120-$500 Engineers Certificate
Overall budget of transplant:
DIY: $3000-$4500
Pro: $4000-$5500
OPTION 2
Positives:
Will go crazy fast, much more power than stock CT9 4efte engine
Engine no. remains the same (no engineers cert / EPA test required)
Some items upgraded would have to be upgraded in transplant engine if more power was desired anyhow (such as intercooler, clutch etc)
Kit available with much success
Running higher compression will give better off boost performance
Negatives:
Cost
Gearbox has to be treated with more respect
Brakes aren't as great as import half cut
Many things are required to happen to do this upgrade
Expected Costs:
$300 2nd hand turbo
$3160 Comprehensive turbo kit (including ecu, manifold, lines, air filter, fuel regulator)
$1100 Turbo back exhaust (including dump, flex, cat, muffler, fitting)
$1275 Water / air intercooler (including piping, hoses, clamps etc)
$430 New clutch to hold the power
$300 Tune
$40 Turbo happy oil
$150 Injectors (such as 4agze)
Pro Installation:
$650 remove / install old / new turbo setup
$150 install water / air cooler
$250 clutch
Overall budget of 4efet
DIY: $6750
Pro: $7750
What corners you can cut:
Load preset on ECU by Dale, -$300 tune
Cheap 2nd hand intercooler + mild steel piping, -$600
Use stock clutch (will slip after 6psi), -$430
Cheapest budget cutting corners DIY: $5450
The difference in price is quite substantial, but so is the power output
After the conversion / turbo:
Further upgrades you can look at:
SUSPENSION! sway bars, camber kits, shocks, springs etc, very fun!
Even larger injectors
Fuel pump
Boost controllers
Limited slip differential
Engine internals
More engineers cert's
for ease the first one id say, would you be doing the work yourself?
Can go with either it's up to you, wiring and management are your deciding factors here all the metals the same in one way or another you'll need to have the car off the road for atleast 2-3 days for the wiring + engine work mabe more....as above who's dong the work? Have you thought about exhaust/intercooler?
me and my mates could do the engine bits but wiring is :) ..
is it possible to put 4efte in but use emanage and a piggyback ecu system?
was thinking of leaving is standard for the moment... with TMIC and custom exhaust...
want it running 160bhp...
The only 3SGTE converted thing I've seen is on TGTT, in a GT
Try asking Fensport? They've converted a Bug-eye to run a 3SGTE!
If you were to go 4efte, I'd just buy the engine whole and get someone to sort the looms out for you. Greddy EMB or another piggyback won't do anything if the engine doesn't run lol
Oh and that 'Rolla is awesome!
lol i see what you mean..
who can do wiring?
how hard would it be?
thinking of doing it in november hopefully...
(3sgte is gt4 (turbo), the trd 2000 is 3sge from celica gt (non turbo))
Dunno bro that was what was putting me off converting my N/A!
I think it is quite a fiddly job tbh, try PMing Jay, he converted both Phil's & Joz's cars.
Also I think Aze & Gaz@ Pukka offer a 4efte conversion service, you could ask them? They do Starlets, but I'm sure it wouldn't be too hard/different with a Corolla that shares the same engine?
When I had my 5 door corolla G6, Fensport didn't want to touch my planned conversion from 4EFE to 4EFTE.
They said it wasn't worthy for them. I was rather disappointed at the time.
who would you recommend i go to?
need a good job for next to nothing really...
i know that wont be the case but never know lol
i have both the interior loom and engine loom here for a turbo conversion but not sure if it would work at all with your corolla, engine loom might if your running a 4efte out a starlet.
  • 10 years later...
@AZE@A&G_TUNING Hi. This post is old but was wondering if you ever swap a 4efte in a Corolla 1998 E11. Like the rally WRC European version. Thanks
On 9/18/2010 at 11:49 PM, miib14 said:
found this on AUSC
You have 2 options.
Block is the same
Crank is the same
OPTION 1
Bolt in fit
Fairly cheap
Goes fast
Expected Costs:
$40 Oil
$16 Spark plugs
$30 Fuel Filter
$7 Oil Filter
$65 Timing belt
$150 Water pump
Free: EPA test
DIY: $3000-$4500
Pro: $4000-$5500
OPTION 2
Positives:
Negatives:
Cost
Expected Costs:
$300 2nd hand turbo
$300 Tune
$40 Turbo happy oil
Pro Installation:
$250 clutch
DIY: $6750
Pro: $7750
Fuel pump
Boost controllers
Engine internals
@sam44 have you seen this old post? What do you think?
