keirz Posted December 3, 2006 Posted December 3, 2006 i have read some good reveiws on ground wire kits. has any one fitted one and how easy is it? thanks in advance.keirz Quote
keirz Posted December 3, 2006 Author Posted December 3, 2006 oi i'm the one asking the questions Quote
Idrees Posted December 3, 2006 Posted December 3, 2006 haha sorry mate don't bite my head off!! Quote
keirz Posted December 3, 2006 Author Posted December 3, 2006 it gives your car better earthing and can improve the performance of you electrical equipment ie sterio, lights, also throttle response due to more power being available to the ignition ect. prob only a minimal improvment but when you have heater, sterio and lights all on, it can drain power. Quote
Idrees Posted December 3, 2006 Posted December 3, 2006 Ahhh, might have to look further into this. The interior light and clock don't work without the engine running, bulb and fuses are fine though. The earthing was a bitch for the inlet mani we fitted today as my bro lost the nut! Quote
Blue Icarian Wings Posted December 3, 2006 Posted December 3, 2006 Better return to the battery wire, improves the quality of the electrical circuit, as keirz saidIt reduces electrical noise, meaning your audio gets cleaner power, the ecu won't corrupt data, your fuel injectors won't get dodgy open/close signals etc Quote
Bourkey Posted December 3, 2006 Posted December 3, 2006 ive got one of these in my starlet.its nothin amazing to be honest.it does add a little bit of grunt to it and i have also noticed a better petrol consumption.the major difference i thought was the radio sounded better an the lights are brighter.it was worth it though.ill get a picture of it tomorrow. Quote
ecksjay Posted December 3, 2006 Posted December 3, 2006 ground wire kit?just get some random welding cable or random power cable from anywhere for next to nothing and double up all the earth connections under the engine bay, that'll do the exact same job. Quote
keirz Posted December 4, 2006 Author Posted December 4, 2006 yeah that would work! thing is i am getting this cheap if i buy another item so just wondered to pay that little extra and get one. Quote
scutch0 Posted December 11, 2006 Posted December 11, 2006 i keep haing a big problem with my leccy windows taking ages to go down... quite tempted to try one of these kits as ive added 3 more eathing straps to my battery to the chassis and its still dimming lights when i flick on the washers etc. Quote
keirz Posted December 11, 2006 Author Posted December 11, 2006 thats why im gonna get one because my lights dim lots when sterio and other bits are on so it must be draining power. will order mine soon i think. Quote
Mart Posted December 12, 2006 Posted December 12, 2006 What kind of audio system do you have in your car keirz? Is it just the standard Starbo speakers? Quote
scutch0 Posted December 12, 2006 Posted December 12, 2006 a sub and amp will still make your lights dim. Quote
keirz Posted December 12, 2006 Author Posted December 12, 2006 ive got a mutant amp and 12" sub, infinity 6x9s and mutant components. so it does drain the power a fair bit. Quote
Idrees Posted December 13, 2006 Posted December 13, 2006 My brothers got a 1000 watt amp powering 1800 watts of subs. It drains plenty so this may help! Quote
nick gt turbo Posted April 7, 2007 Posted April 7, 2007 seen these on ebay for bout £25. they just look like the power cable that ud have on your amplifier? mite do it the cheep way though and buy some cables. Quote
Fogdoggydog Posted April 7, 2007 Posted April 7, 2007 So what EXACTLY is a ground wire kit?Some fancy electro bit of gubbins? Something you fit to a battery? Or is it a handful of thicker wires?And how/where do you fit it?Feel free to answer questions I've missed. Basically I want knowledge. Quote
Glanza_Ragger Posted April 8, 2007 Posted April 8, 2007 its literally a handfull of wires, and if you buy a stupidly prced hks kit for instance, you get a purple ring piece where all the wires attatch to..waste of money for a branded kit, go to an audio shop, get some nicely sized gauge amp power wire, and make your own..you can get junction blocks from there too, polished if your fancy.one line goes to battery earth into the junction block, then comming out of the other ports on the block the amp wires go to the chassis earthing points.it just means your getting a better earth rather than the tiny little earthing wires as standard.do as ecks said and make a custom one for peanutts. Quote
keirz Posted April 8, 2007 Author Posted April 8, 2007 the one i was looking at is only £20 any way, this would be about the same price if i brought the wires and block seperatly wouldnt it? that price sounded ok to me. Quote
Fogdoggydog Posted April 8, 2007 Posted April 8, 2007 Ok, sweet!So someone said that it may improve performance or fuel consumption. What would wires would I need to change to see an improvement?[edit]Also I've been browsing the interweb (again) for info on tuning my engine and found on a perodua owners forum that voltage regulators can improve performance as well. Any thoughts on this?I found a handy-as voltage regulator that plugs into the cigar lighter too.Click here, here and here.[/edit] Quote
