right i have tried all the other guides on how to stop the fan from running to no success! so i have all these plugs and not been able to stop the fan from running! i also carried out a diagnostic test and it came back with 22 wich is coolant temp sensor! open or shorted ciruit! i have been told its to do with the AC removal! they also said to plug the AC sensor back into the 4 pin plug by the battery!
this one. but i dont have it. it was binned long ago!
also to the front of the car by the cooling rad i have these pair of plugs! one used to do the fan and one the condensor unit but do i need to link them out?
any help is greatly appreciated
Bill.
this question is popping up alot LOL
bridge the connection there will have been a sensor you took off while removing the aircon, get that plug and bridge the baby its located behind the battery (on the ep82)
That sensor was binned long ago my friend so I need to know what cables to bridge? Unless someone has a sensor they can sell me? I have tried bridging that 4 pin plug in ever way but the fan only works when I turn heating blowers on inside the car( which reallyconfused me lol!)
Bill.
  • 2 weeks later...
any one know anything about this code 22! i have changed the thermostat housing the two sensors in the thermostat housing! ( thermostat sensor and the temp gauge sensor!) i have also checked the knock sensor! anything else i can check as its not running right and it keeps throwing this fault code up and its doing my head in now grr!
Bill.
No think it's the ecu fuse out for 30 seconds or to be safe just disconnect the battery for 30 seconds then you 100% know it's reset
