1990timeismoney Posted October 1, 2010 Posted October 1, 2010 Hi ive just brough a new decat and the decat on the car has to sensors pluged in and the new decat only has one hole which sensor can be removed.or any idea what they are. any help would be great.thanks Quote
micky boy Posted October 1, 2010 Posted October 1, 2010 You need to keep the top one (lamba sensor) bin the bottom one its no use Quote
lukEp Posted October 1, 2010 Posted October 1, 2010 The bottom sensor is just a thermal on/off switch. It's always off till the cat becomes to hot. Then it switches the light on. On the dash but because you have a de cat (no cat) it's not needed anymore just unplug it and put it in a draw and forget about it. Luke Quote
1990timeismoney Posted October 1, 2010 Author Posted October 1, 2010 The bottom sensor is just a thermal on/off switch. It's always off till the cat becomes to hot. Then it switches the light on. On the dash but because you have a de cat (no cat) it's not needed anymore just unplug it and put it in a draw and forget about it. Luke thanks very much for the help thats answered the question. Quote
lukEp Posted October 1, 2010 Posted October 1, 2010 You welcome, only reason I know is because I had same problem with mine Quote
