Kennedy Posted November 18, 2010 Posted November 18, 2010 Thought i would post this in here as due to my brake upgrade I need longer wheel studs.Anyone know where I can get them or what size I would need?If this is the wrong section please can a mod move it Quote
Steve GT Posted November 18, 2010 Posted November 18, 2010 il move it to the wanting to buy sectionas for the studs im not sure but johm (ro55fumi) has just put some uprated brakes on his dont know if he's bought some longer studs might be worth PM'ing him and asking Quote
Kennedy Posted November 18, 2010 Author Posted November 18, 2010 ^^Thanks mate..wasn't sure where to post it.I'll give him a PM when I get home Quote
Steve GT Posted November 18, 2010 Posted November 18, 2010 no need I've just text himil let you know when he replies Quote
ryan lang Posted November 18, 2010 Posted November 18, 2010 what brakes have you got? me and jon didnt use them for our levin twinpot upgrades Quote
micky boy Posted November 18, 2010 Posted November 18, 2010 Kennedy's useing GT4 calipers so he will need to space the wheel out a fair bit!! Quote
Steve GT Posted November 18, 2010 Posted November 18, 2010 nah john said he used his standard ones on his levins lol cant help you then matey Quote
ryan lang Posted November 18, 2010 Posted November 18, 2010 i had to space mine by 6mm, and then obviously however much thicker the disc is compared to the tiny n/a disc Quote
Jozinobi Posted November 18, 2010 Posted November 18, 2010 Quite a few questions asked and Kennedy doesn't actually know what he needs so it'd be best to have this in technical for future reference For the record Im not using longer wheel studs or spacers on my twin pot conversion either.Its all about having an ideal brake disc size which will give you the happy medium.I had mine sorted by mc_chu so I couldnt tell you the spec besides the fact they are 260mm.CheersJoz Quote
Kennedy Posted November 18, 2010 Author Posted November 18, 2010 As said im using GT4 calipers and I believe they are Coralla discs, much bigger than the standard glanza disc anyway.I've been told to go to demon tweaks and they should be able to sort me out..be handy if someone knew the width/length of the standard studs though? Quote
miib14 Posted November 28, 2010 Posted November 28, 2010 gt4 caliper infobeen told, you need to getst205 discs (315MM DIAMETER x 32MM THICK)get them machined down to 300mm and redrilled as 4 stud..or get impreza 295mm discs and redrilled as 4 stud and spacer between pads and pistons so piston doesnt pop out because disc is alot thinner than celica ones.. Quote
Kennedy Posted December 3, 2010 Author Posted December 3, 2010 I believe it has Corolla discs in at the min...I can find out for sure.But because a spacer is needed behind the disc its taking up space on the studs and I've been told to just get some longer studs.I know demon tweaks sell them so it might just be a trip up after xmas.Thanks for that info though miib Quote
ryan lang Posted December 3, 2010 Posted December 3, 2010 if you do get a set from demon tweeks dude, could you pick me up a set and ill paypal the money to you, because i cant find the sods anywhere! Quote
ryan lang Posted December 15, 2010 Posted December 15, 2010 http://www.fensport.co.uk/Parts/Model_40/Category_7/3469 just ordering 1 stud atm, and if it fits ill order the rest Quote
BoostJunkie Posted January 9, 2011 Posted January 9, 2011 Just spotted this ryan you are a F*****G legend i've been trying to find longer studs for ages, Quote
ryan lang Posted January 9, 2011 Posted January 9, 2011 only problem is bud, the might need skimming on the spline by about 0.1mm, thats a tiny tiny amount, because i tried to get mine through, and had no chance of pulling it all the way through, ill try get a tidy pic of what happened for you today and ill post it up a bit lateryou could always use a hand file just take a tiny bit off, but best to get it done accurately dude Quote
BoostJunkie Posted January 9, 2011 Posted January 9, 2011 only problem is bud, the might need skimming on the spline by about 0.1mm, thats a tiny tiny amount, because i tried to get mine through, and had no chance of pulling it all the way through, ill try get a tidy pic of what happened for you today and ill post it up a bit lateryou could always use a hand file just take a tiny bit off, but best to get it done accurately dude Please mate if you can get me a pic would be brilliant cheers Quote
lukeEP82 Posted April 13, 2012 Posted April 13, 2012 Does anyone know the size of a standard wheel stud. I think it's M12x1.5 but I don't know the length. Quote
Idrees Posted April 13, 2012 Posted April 13, 2012 I am not sure of length either, we can supply genuine Toyota ones at a good price though. If I have spare I will measure it up for you. Quote
lukeEP82 Posted April 13, 2012 Posted April 13, 2012 Thanks mate. I'm just trying out some different wheels and they have a thicker flange and the studs are about 3mm to short. I want to know the standard length so I Know what I need. Do you sell longer studs. Quote
lukeEP82 Posted April 13, 2012 Posted April 13, 2012 About 5mm longer should do it. I may go 10mm and see how the wheels look with 5mm spacers. Quote
