scutch0 Posted October 27, 2005 Posted October 27, 2005 nah its a 4efte one. the 5efhe is a 5efe with the higher compression, tougher rods, 421 manifold and downpipe, and it uses a 4efte inlet manifold (on non acis equipped ones), a 4efte distributor and a 4efte throttle body.i got confused when i bought my fhe and it had 4efte parts on it!! Rich. Quote
scutch0 Posted October 27, 2005 Posted October 27, 2005 heres a side veiw of an acisand one fitted to a 5efhe...Rich. Quote
markweatherill Posted November 2, 2005 Posted November 2, 2005 I managed to obtain one of these tubular manifolds and now I need the idle control valve from a 4EFE throttle body.I'm hoping the 4EFE type idle control valve will bolt straight on to my 5E throttle body in place of what's there.So, does anyone have a spare 4EFE throttle body in any condition.... I'm only after the bottom part. Quote
markweatherill Posted November 2, 2005 Posted November 2, 2005 My throttle body doesn't have the idle control valve fitted to it. It has a water heated chamber instead and the idle control valve is elsewhere.My plan is to obtain the idle control valve assembly from a 4EFE throttle body and fit that to my TB.(I just got a quote from Toyota for the part - £106 + VAT. :P ) Quote
scutch0 Posted November 2, 2005 Posted November 2, 2005 hmmm, not 100% sure your gonna be able to do that bud. if i still had my 5e i could have looked into it for you. im confused, where did you say the idle control valve is on your fhe? Rich. Quote
markweatherill Posted November 2, 2005 Posted November 2, 2005 It's in the end of the manifold. In post #25 you can see it on the left, with the electrical wiring still attached.I am not so sure either that the 4EFE part will bolt right on, so instead I could use my existing idle control valve with a pipe spliced into the brake servo hose. Quote
scutch0 Posted November 2, 2005 Posted November 2, 2005 ah. i see.what you said would probably be best mate... thats the only thing i can think of...to be honest though mate, i can see this not working out for you... sorry to put a downer on it, but you could be loosing your idle control because im not too sure n how well it would work. but all the same i hope you prove me wrong!!Rich. Quote
markweatherill Posted November 18, 2005 Posted November 18, 2005 Well, the tubular manifold is on the engine, all appears to be working, I just have to make a bracket for the Idle valve and tidy up the hoses. :angry: :angry: Quote
Guest Enzo Posted November 18, 2005 Posted November 18, 2005 thats good to hear!have you taken it for a spin yet? Quote
markweatherill Posted December 10, 2005 Posted December 10, 2005 Here's a picture (at last). Sorry it's took so long! Quote
