Check out my build, I used a hacksaw then carefully sanded the cut bits down using a dremel tool. If you do it carefully enough you can get away with not respraying the cut bits, although you could probably use a touch up brush!
It looks pretty bare though unless you put mesh in (again pics before, unmeshed after and meshed are in my build thread!)
Click my sig, it even says so ;)
oopss lool cheers mate
use black tape ;)
lool would that work :D
just an idea 4 ya pal.
i just cut all the downwards slats
oh cheers mate just cut them of did ya.?
