heyi wondered if it would be possible to just take the enginefrom the corolla 1.6 with the engine 4a-fe and just drop it into n n/a starlet
what would need upgrading and stuff?
cheers
possibly, depends if the engie mounts are the same,
you would need gearbox, driveshafts and maybe hubs too - probobly more effort than overall gain but could be interesting - you'd also have to get the full loom and ecu to make sure it runs right
glanza/gt... there isnt much point in the others as the cost to power ratio isnt worth it. you spend more time and effort getting it to work and run then you would enjoying it
bide your time mate we have all had to do it then slap a 4efte in there or just buy a glanza/Gt
u can drop a paseo 1.5 5efe strait in i supose, if you can find one, its a strait swap and leaves you with 90 hp. for anymore power you are better off putting a 4efte glanza engine in, or just buy a gt or a glanza and sell your car.
For the effort it would take to fit a 4AFE you may aswell use a 4AGE, even if it's an early 16v, way more tuning potential than a 4EFE/5EFE/4AFE.
If you want to go down the N/A route the 4AGE is the way forward IMO. But the 4EFTE is still the best option when you weigh everything up.
The 4AGE is basically the high performance version of the 4AGE (F or G in the engine names denote wether it's an economy or performance based engine).
It was found in many Toyotas and there are many versions of it, the most recent and most powerful being the "Black top" 20v, which has 5 valves per cylinder and ITB's. :(
lol i dont want a rocker or a racing engine, only abit more power than the 75 its normally has. does the 75bhp un modified feel slow or slugish by any chance?
  • 3 weeks later...
a 4afe or 7afe would be a fairly straight swap but its a heavy engine as the block is cast iron
but having a 1.8 with 140bhp with boltons would be fun as would the induction roar.
two of the mounts are the same(geabox and back mount), the third mount you would have to fab,
using the donor cars clocks and engine loom would be the only point in the converstion,
donor cars are so cheap now to do this(bug eyed corolla,mk1 avensis)
