Amjad Posted December 15, 2010 Posted December 15, 2010 So for some reason my driver's side wheel has noticeable positive camber, no idea why, I've never crashed or bumped the wheel lolI wanted to get some camber adjustment bolts so I can restore the normal settings, or rather dial in a bit on negative camber!I've seen these Eibach ones on Ebay which are pretty cheapEibach Front Camber BoltsAnd Whiteline onesWhiteline Camber BoltsI think I'd rather get the Eibachs as they have a greater range of adjustability and are cheaper!I was just wondering if anyone had any experience with these, and if so are they easy to fit?Anything I should be aware of before buying them?ThanksAmjad Quote
The Toffinator Posted December 15, 2010 Posted December 15, 2010 I cant respond properly, but man your car will handle when its finished!Jealous Hahaha Quote
Amjad Posted December 16, 2010 Author Posted December 16, 2010 Lol thanks! If money was no object I'g get myself Meisters, Cusco front brace, Ultra Racing 4 point lower arm brace, Miracle/Zisco Cross Brace and some sticky tyres Bump! Quote
LukeH Posted December 16, 2010 Posted December 16, 2010 Yea i was looking at these the other day, was trying to work out how the hell they worked. :EDIT: just looked at the link to the ebachs, doesnt really look particularly robust, just save for some coilies i reckon Quote
Amjad Posted December 16, 2010 Author Posted December 16, 2010 I think they just replace one of the bolts on the shock, but I don't know which ones and how easy it'd be, don't wanna screw it up! Quote
LukeH Posted December 16, 2010 Posted December 16, 2010 its just replacing the top or bottom bolt at the bottom of the shock.i dont like the idea of replacing the bolts for smaller onse. will just put more strain on a smaller size bolt surely? Quote
Josh@TunerLifestyle Posted December 16, 2010 Posted December 16, 2010 and all i had to do was let the bottom hub to sturt bolt come out theres your camber!ahaa Quote
Josh@TunerLifestyle Posted December 16, 2010 Posted December 16, 2010 and just for the record i dont suggest anyone dose this! lol Quote
Amjad Posted December 16, 2010 Author Posted December 16, 2010 Hang on a sec, did that occurr due to these bolts or did that just happen? lol Quote
Josh@TunerLifestyle Posted December 16, 2010 Posted December 16, 2010 bolt came loose... bolt fell off on the motorway.. car went skitz and ha to pull over to find that lolohhhh sorry nothing to do with the bolts your looking at lol was making a joke about camber Quote
Dan507 Posted December 16, 2010 Posted December 16, 2010 Really dont understand how these work, is the bolt smaller them OEM Causing the adjustment? - If so sounds kinda dodgy. :s Quote
G14 NZA Posted December 16, 2010 Posted December 16, 2010 I used camber bolts on all four corners of my MR2 turbo with no problems. You could also go to Toyota and get a pair for about 6 -7 quid.Mark Quote
Amjad Posted December 16, 2010 Author Posted December 16, 2010 Is it tricky fitting them?Would Toyota have them for the EPs? As I believe our cars' camber can't be adjusted unless you have coilovers? Quote
G14 NZA Posted December 16, 2010 Posted December 16, 2010 90105 - 1500490105 - 1500590105 - 15006Each part number above gives a set amount of adjustment but you can double up if you need to. I would certainly trust Toyota ones over the very thin looking ones your looking at on ebay. Fitting them is a garage job to get them set to the right angle.Mark Quote
Amjad Posted December 16, 2010 Author Posted December 16, 2010 Do I need to order those 3 parts for one side?What do you mean by doubling up?I'm curious as to what sort of range of adjustment they'd give, as my driver's side front wheel has major +ive camber! Quote
G14 NZA Posted December 16, 2010 Posted December 16, 2010 To do just the drivers side you would need only one of those part numbers, which one would depend on how much adjustment you need. iirc toyota's bolts give 0.75, 1.5 and 2.25 degrees.Also when I fitted my D2 coilovers my Glanza it had quite bad positive camber, worse than yours i'd say and using the topmounts the garage only adjusted the camber 1.5 degrees.Doubling up would be two bolts on on strut.Mark Quote
ryan lang Posted December 16, 2010 Posted December 16, 2010 doesnt sound to clever to me tbh :/get some coilys Quote
Amjad Posted December 16, 2010 Author Posted December 16, 2010 Okay thanks for your help Mark! One more question, well two, I assume those Toyota bolts are the same thickness as the standard fit ones? And with the 2.25 do you mean I can adjust it +/-2.25?Ryan I can't afford them dude, if and when I ever get Meisters it'll be a long way off, and they'll be used Quote
G14 NZA Posted December 16, 2010 Posted December 16, 2010 Toyota bolts don't have adjustment which is why they do three different ones. Long story made short, i bought super street coilies for my MR2 without adjustable topmounts so i bought two sets of the same type of bolts you saw on ebay. They looked very thin and weak so went to Toyota to get brand new topmounts and asked them about the camber bolts i'd bought and they said to use the ones they do. They look like a proper bolt and were £3ish each.HTHMark Quote
