im after buying a set of these alloys in the near future wanted to know if anyone could help. im unsure if they would fit over my wilwoods. the alloys are Size:15;Pitch:4H-114.3;Offset:+19;Color:Black;Disc Face type b jwidth:6.5jj;
and ive got 10mm spacers already on the car.
thanks for any help
mine are 15 inch and with 10mm spacers just fit over my wilwoods just wanted to check the new ones would fit as im sure ive seen someone talking about fitting toms alloys over wilwoods and them not fitting.
They should fit becuase its a low offset and you could always use the spacers. but this is easy to say when it isn't my money.
Also im guessing you're getting the 4x100 ones unlike the ones you said above.
i hope they will fit dont fancy spending all that money on them not to fit. i was looking for 8" wide but they wasnt on the options list.
First Point those are 4x114.3 PCD you'll need 4x100 to bolt straight onto a starlet..
As for the will they clear my brakes tell me if i'm starting on something you already know but...
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
So the wheels you are looking at are +19 offset with what looks like quite alot of dish this means that the spokes will be very close to the center line of the wheel ginving very little room for big brakes like the willwood 4 pots your running. You'll see most cars running big brake setups using wheel with a high positive offset and a spoke design that will be close to the edge for the rim to give the most amount of room for brakes.
thanks for the info dude ive also got 10mm spacers so hopefully they will fit
Problem with the 10mm spacers is you'll be pushing the wheels even further out so will be the same as a +9 offset when the standard starlet offset is +38 that will mean that your wheels will be 30mm further out than stock this then might cause you problems catching arches etc.
The back is stripped out and its lowered just enough so it should be ok my current alloys poke quite abit at the min and had no problems with hitting the archs
