Just wondering which FMIC kit is the best fit for an automatic EP91, the gear box is huge and having studied pics of the pipe routing of peoples kits on here it looks like most will block access to the transmission fluid dip stick.
Thanks
Mark
Don't worry dude it does fit but you have to loosen the trans stick so the fmic pipe can fit in. I used a hdi fmic it did fit. The stock rad is fine by the way :mellow:
