Dickydan Posted January 25, 2011 Posted January 25, 2011 how much would the driverside brakepad carrier be? as i need a new 1? with caliper bolts too. Quote
Dickydan Posted February 11, 2011 Author Posted February 11, 2011 what car dude?sorry forgot to state ep82 gt turbo j reg, i got the caliper now put it on and now its throwing my bro to the right big time, anyone have a idea of the problem?? recent work been done:new hubs at frontnew discsnew padsbut i can see hes abit low on brake fluid and ill need to bleed the brakesbut that cant be the cause im sure? Quote
daz gt turbz Posted February 11, 2011 Posted February 11, 2011 jack the car up and try spinning the wheel, be able to hear if anything is catching or feel it binding as it wont spin freely. Quote
Dickydan Posted February 11, 2011 Author Posted February 11, 2011 jack the car up and try spinning the wheel, be able to hear if anything is catching or feel it binding as it wont spin freely.it spins but sounds as if pads are tryin to bed in if u get me? slight scrape Quote
The Toffinator Posted February 11, 2011 Posted February 11, 2011 Slight scrape is fine mate, there usually is a bit when you put new pads in Quote
Dickydan Posted February 11, 2011 Author Posted February 11, 2011 Slight scrape is fine mate, there usually is a bit when you put new pads inyee as they need to bed in so i know thats fine, but just wondering why its throwin my bro to right BIG time, i need to bleed the brakes asap, whats the best brke fluid to put in?could this be the problem? but he has brakes?? as in the pedal is fine and he stops fine nd everything Quote
daz gt turbz Posted February 11, 2011 Posted February 11, 2011 yee as they need to bed in so i know thats fine, but just wondering why its throwin my bro to right BIG time, i need to bleed the brakes asap, whats the best brke fluid to put in?could this be the problem? but he has brakes?? as in the pedal is fine and he stops fine nd everythingbleed them up and see if it helps then if it dont welgo from there. Quote
Dickydan Posted February 11, 2011 Author Posted February 11, 2011 bleed them up and see if it helps then if it dont welgo from there.yee fair enough, ill soon see, whats the best brake fluid?? Quote
Russleh Posted February 11, 2011 Posted February 11, 2011 id do a complete clean of everythin on the brake setup ie take the sliders out both sides and clean them and regrease them and put everythin back together and see if its still the same. if it is at least ul know its nothing at the actual brake end. dunno if it will help but it would definatly eliminate the calipers if everythings moving freely. Quote
Dickydan Posted February 11, 2011 Author Posted February 11, 2011 id do a complete clean of everythin on the brake setup ie take the sliders out both sides and clean them and regrease them and put everythin back together and see if its still the same. if it is at least ul know its nothing at the actual brake end. dunno if it will help but it would definatly eliminate the calipers if everythings moving freely.yeah true, cheers people will get onto it, just need to know what brake fluid is recommended? Quote
Keri-WMS Posted February 13, 2011 Posted February 13, 2011 Take the stainless pad clips off the carrier if the pads are not 100% free to move, chip the rust off from under them and put it all back. Quote
The Toffinator Posted February 13, 2011 Posted February 13, 2011 Any half decent brand will do the job fine mate, but as above give the calipers a service, just undo the bolts through the sliders, remove them and grease up the seals, then do the same with the piston seal, back together, give em a bleed and that should have the brakes working perfectly dude. doesnt take long either tbh! Quote
