federalman Posted February 4, 2011 Share Posted February 4, 2011 Fixed the boost leak I've had since the manifold was fitted. Just needed a new piece of hose between the hotpipe and to pmount intercooler. I've now come to setting up the actuator and its boosts worse than when i had the leak. I'm running out of adjustment before the wastegate is completely shut. Its running about .4 bar the same as with the boost leak and the wastegate was shut then. Full boost now comes on about 4k which is quite late. So if I adjust the actuator to being completely shut and still not running .8 bar anyone got any ideas what I can. Would a boost controller get me to the boost I'm after. Cheers guys matt. Quote Link to post Share on other sites
Guest Enzo Posted February 9, 2011 Share Posted February 9, 2011 have you lengthened or shortened the actuater arm dude, Quote Link to post Share on other sites
federalman Posted February 9, 2011 Author Share Posted February 9, 2011 wastegate is shut and im now running .6 bar duno how else to get it back to .8 Quote Link to post Share on other sites
Guest Enzo Posted February 9, 2011 Share Posted February 9, 2011 did you lengthen or shorten the arm on the actuater? Quote Link to post Share on other sites
federalman Posted February 10, 2011 Author Share Posted February 10, 2011 Err shorten the boost increased as i shortened it but ive now run out of adjustment as the wastegates shut Quote Link to post Share on other sites
N80Jamie Posted March 1, 2011 Share Posted March 1, 2011 Bump for this thread. Similar problem to me Quote Link to post Share on other sites
mini valver Posted March 1, 2011 Share Posted March 1, 2011 i had these problems and i found it out to be another boost leak. my leak was coming from the arc dump valve it was not sealing and in turn i shafted 2 turbos finding what the problem is. if your cars wastegate is totally closed it is more than likely boosting like mad but it is leaking some were Quote Link to post Share on other sites
