Liam_D Posted February 5, 2011 Posted February 5, 2011 Got one slight problem to address which is quite gay to be honest Car runs at a really cold temperture all the time. Like the needle is constently on the C and when you stop at a set of lights or something the temp needle rises to the correct tempurture anyone know what this could be?Car runs fine and isnt overheating or anything. Anyone? Quote
bucketep91 Posted February 5, 2011 Posted February 5, 2011 mine used to do that, itd warm up properly then when i drive off it would drop down. changed the thermostaqt and never had a problem again Quote
daz gt turbz Posted February 5, 2011 Posted February 5, 2011 1st day, 1st problem! defo the thermo stuck open mate, they are only like a tenner and easy to change! other than that things are good with it? Quote
Sparky Posted February 5, 2011 Posted February 5, 2011 Everyone has had to change the thermo when they buy a starlet turbo, even me Cheap and easy fix though mate Quote
Liam_D Posted February 5, 2011 Author Posted February 5, 2011 Good to hear not exactly strapped for cash at the minute! So good to hear its a easy fix! Wheres the best place to buy one from? Quote
BAZ2CRAZY Posted February 5, 2011 Posted February 5, 2011 Straight from toyota man. not that expensive. i replaced mine before it went on the road, peace of piss to do. Can also whack fresh coolant in too, maybe some fancy samco hoses Mitch Quote
Guest Enzo Posted February 5, 2011 Posted February 5, 2011 i sell them here, its an easy fixm with two bolts holding the thermostat housing on, the bolts are a bit brittle mindhttp://www.ukstarletclub.com/forums/index....item&id=172 Quote
Liam_D Posted February 6, 2011 Author Posted February 6, 2011 Awesome thanks Geo ill probs be in contact to order one man! Just got to wait til Monday and see what our suppliers at work can get me a geniune one for. Quote
Josh@TunerLifestyle Posted February 6, 2011 Posted February 6, 2011 was just about to recomend enzo as i got mine from him mine had exact same problem and thermostat sorted it out Quote
Liam_D Posted February 6, 2011 Author Posted February 6, 2011 Yeah cheers mate going to see what i can get through work tomorrow, its annoying ive only just bought the thing grrr!! Quote
joel_ep91 Posted February 6, 2011 Posted February 6, 2011 prob a silly answer but it could be a low temp thermo Quote
Liam_D Posted February 8, 2011 Author Posted February 8, 2011 Changed the Thermostat yesterday and now the car runs perfect Quote
Josh@TunerLifestyle Posted February 8, 2011 Posted February 8, 2011 Changed the Thermostat yesterday and now the car runs perfect WEEEEEY! Quote
