I know a lot of threads pop up about smokey cars that aren't actually faulty in any way. I get some smoke on idle but havnt really worried much about that but sometimes shortly after the car is warmed and i step onto boost i get a lot of white smoke pouring out the exhaust. This might be a coincidence but it has only seemed to do it in 2nd-3rd gear at the minute. It doesn't do this all the time, just on occasions. Is this something to get worried about?
First thoughts i'd say condensation...... but you never know.
Thats what i was hoping becasue it only seems to do it when i come on boost for the first few times after the car is warmed up.
white smoke if it aintr condensation... then it cud be early start of headgasket failure...
Is there anything i can do to test if the headgasket is on the way out?
i used to have a xr3i cabby and i had similir smoke issue was bit grey the smoke and was valve stem seals but havent heard much about them failing on the starlets
mine smokes a white smoke on idle when cold, will keep smoking for about a mile then know smoke what so ever when warmed up
I'll keep an eye on it and see how it goes! Cheers for the replys :D
(Im a big worrier when it comes to my car, expect many more of these threads :D )
