Josh@TunerLifestyle Posted March 16, 2011 Posted March 16, 2011 rite guys I've been having this problem for some time now and its really baffling me! my engine management light came on while i was on the motorway and i couldent think why, i wasn't driving fast or on boost so it wasn't fuel cut.after this i did a diagnostic test and it came up with the falt code 42it says its the VSS sensor wich means if my coolant temp is up to temp and the rpm of the car is between 3000 and 5000 rpm for 8 seconds ( something like that neways)this will cause the code to come oni was told to change the coolant temp sensor ( wich i have done twice now ) still no luck!tried doing some research on the web and theres hardly any info on it!so could someone please please help me?what is the VSS sensor and where can i find it??what are the other things i can do to get this light off while im on the motorway??cheers josh Quote
micky boy Posted March 16, 2011 Posted March 16, 2011 Have you poped into Toyota yet? to see if they know what its is orr where it is lol Quote
Josh@TunerLifestyle Posted March 16, 2011 Author Posted March 16, 2011 Never really thaught of that lol dealers by mine are useless, they didnt even no what a glanza was ! Quote
micky boy Posted March 16, 2011 Posted March 16, 2011 Well i live near toyota, if i get some spare time i will have a pop in and ask the lads there and let you know Quote
micky boy Posted March 16, 2011 Posted March 16, 2011 i've just also found this..if you scroll down abit it says the vss is either located on the transmission or behind the instrument cluster...when you changed your cluch did you plug the speedo in right? orr pull it out the back of the clocks abit? im just trying to think of things so if i sound thick just leave me to it lolhttp://www.wheelsjamaicahost.com/wheels_fo...?topic=106686.0 Quote
Josh@TunerLifestyle Posted March 16, 2011 Author Posted March 16, 2011 Yehh speedos all fine, this has been going on before i changed my clutch lol i knoww im a painn lol Quote
micky boy Posted March 16, 2011 Posted March 16, 2011 haha i will find out where it is for some reasion i think its one of the sensors on the gearbox but witch one? lol i will try pop into toyota mate Quote
Josh@TunerLifestyle Posted March 16, 2011 Author Posted March 16, 2011 Cheers dude im sure someone on here will no what it is! Quote
Socks Posted March 16, 2011 Posted March 16, 2011 vss is vechile speed sensor... but there a cable on glanza's there isnt a sensor is there doesnt make any sense? :s Quote
Josh@TunerLifestyle Posted March 16, 2011 Author Posted March 16, 2011 I knoww lol baffled me! But on the list of falts number 42.. vss is there ! Mite be something to do with my ecu? Quote
Socks Posted March 16, 2011 Posted March 16, 2011 try another ecu? there only plgu n play.. 4 blts and the glovebox can be removed to gain access Quote
Josh@TunerLifestyle Posted March 16, 2011 Author Posted March 16, 2011 Could do, you know how much ther going for roughly? Quote
micky boy Posted March 16, 2011 Posted March 16, 2011 Befor you go spending money see if someone can lend you one Quote
Socks Posted March 16, 2011 Posted March 16, 2011 no one local spend 20mins just plugging and playing!?4 bolts and 3 connectors all u need to change them! Quote
Josh@TunerLifestyle Posted March 16, 2011 Author Posted March 16, 2011 Spose its possible! But id have to drive the car up to temp and over 3000 for 8 seconds to see if it works lol Quote
Socks Posted March 16, 2011 Posted March 16, 2011 u make it sound like thats a hard thing to do Quote
Josh@TunerLifestyle Posted March 16, 2011 Author Posted March 16, 2011 Lol im just a lazy basterd ! Quote
