when should ct9 hit full boost?
  ollie ryan said:
Full boost is ment to be 2800rpm mine turbo is fucked and I'm hitting it at around 4200rpm
whats wrong with oyur turbo?
just had a tohught my wg has been ported and bet thats something to do with it although still not too sure
  Sparky said:
stock ct9>hybrid anyday
Bang on, I think the problem is people never run a stock ct9 at high boost, they upgrade the turbo then wind the boost up. I did the same with my hybrid, went back to stock turbo and never looked back!
  XPS420 said:
Mine was same as sparky, be about a bar at 2800rpm
my auto glanza boosted max at around 2k which i think is fairly nice and low.
x3, I loved my ct9, was ace fun and hitting a bar in no time!
I dont think your wastegate is "over ported" with it being ported should help cut down in creep.
As above, what are you controlling boost with?
Is the turbo a stock ct9 or a hybrid?
What actuator?
Ive got a feeling mines slow to react aswell.
I had hybrid set to 0.8 bar on the actuator, it used to hit 0.8 bar at around 2800 rpm no problem,
Have now fitted a EBC and set to one bar, it now boosts straight to 0.8 then kinda slows up n hits 1 bar,
realy weird im sure ive got it plumbed in correctly, im sure the EBC states its boosting a bit higher then my gauge shows to
