Fuel Pressure correct?
Just to make sure; im running 0.72bar boost and allowing it to creep up to 0.8ish bar. Had a quick look at my fpr gauge today and it reads just over 2bar pressure. Does this sound about right or will it be running too rich/ too lean.
Cheers ;)
Pretty sure it is something like that. The main reason i asked the question tbh, think it's slightly less. How do i adjust the fpr? Want to set it on about 2.6-2.7 to be on the safe side ;)
haven't fitted mine yet. Although i think its a case of unscrewing the top nut on the FPR and winding back the bolt a little bit. Not sure which way though. Best ask someone who's done it.......
Cheers Starbuck, i'll wait and found out how other people have done there's and adjust mine accordingly ;)
2.4bar is standard...are you running an fcd or anything? if its basically standard dont turn the pressure up..2.4bar is more than enough for a ct9 at .8bar lol! the standard map is pretty rich lol
Ye im running an fcd, fmic, decat, zisco mani, fujitsubo exhaust, re located air filter and a few other bits. I'll double check he gauge again when im out to see if im on 2.4bar. If it's lower, how do i adjust it?
as above if it needs adjusting you just under the top nut and wind the bottom nut in. but the ep91 ecu's run so rich i doubt it will need adjusting. i ran basically standard fuel pressure on a hybrid on the stock ecu at 0.8bar there that rich lol
Its a JAM fcd. No worries anyway, just checked again and it definitely is on 2.4bar. Happy days haha ;)
Hi I've just fitted my jam fcd without fpr and it didn't even idle well I was told the jam fcd only kicks in over fuel cut but myn just leaned out have u any idea wat was wrng.
Thanks
