What is this nipple, looks like a vacuum hose, is it just meant to go to air?
Just to oriantate, you, that is my actuator
and the blue hose comes off the turbo inlet for my relocated air filter.
Thanks
Thats the vacuum hose for the Hi/Low boost but cause you have got the HKS actuator its no longer needed orr if you would like to reconect the HI/low boost then just T-pice it
Theres one bolt holding it on. Think its the timing belt cover bolt. Undo that then just wiggle it and give it abit of manly persuasion :lol:
  • 4 months later...
hi guys I've just fitted a hks acuator like the guy above and i got a spare vacum hose that origanl went to the old acuator and back to a small square box (on the drivers side quite close to the strut) and a second pipe running off some where. is that the little box im suppost to take off went i uprate the actuator. i have an ep82 if that helps.
