got new brake pads for my ep82 tried to put them on the car in college today got them on but the discs would hardly move had my lecturer helping but cant understand it
any of yous have the same problem,done the rear ones about two months ago and they were fine
at first was wondering if it was the right ones but pretty sure they are
there apec pad 421
mine were a bit tight on the sr when i changed mine i used the apec pads to it might just be there a bit to fat!! or that the piston was a bit stiff!! Mine wrere spot on once i had run them in!!!
Hope thats of some help!!
Rob
just grind the pads down a wee bit then it should be sound if ive picked you up right...
yeah you still need to force the piston back in, my friend fitted mine on the weekend (new discs and pads) and he has a special tool to compress the piston back in so he could actually get it all back together, was a big ass clamp type tool.
