Random oil light
On my glanza I have the oil sensor in the original place
I have a sandwich plate fitted so I could install the oil gauge
The problem I have is
Drive normal with some boost the oil light won't come on which is fine
Drive the car hard with lots of boost & the oil light will flicker when I stop !
Also the oil level is bang on the max line .
I'm using magnatec oil
Thank you if you could help as I want to go to santa pod Easter weekend in the car & want it working good.
i get a flicker randomly from mine then it stops and then starts doing it again when ever it fancies it... and this has happened for years of thrashing now
my oil pressure gauge states there is no problem at all so i ignore it, fkin toyotas lol
it only flickers after very hard driving
which is what i cant work out.
if it was earthing out it it would flicker after short bursts of boost !
what psi should be reading on the gauge when sitting idle ?
You've got low oil pressure when the cars been given a bootful as the oil will be hotter and thinner hence the pump won't be working as hard to pump the oil so less pressure. If the pressure is dropping low enough to bring the light on a new pump might be needed.
the pressure is low when the light is on
I was dreading to hear that answer of a new pump needed
Are they hard to fit ?
