Glanza V automatic radiator
Hi, can anyone point me in the direction of where to buy a radiator for an automatic V please?
Here's what i can find:
http://www.thecarparts.co.uk/acatalog/Radi...__1_3_2364.html
http://camskill.co.uk/products.php?plid=m19b0s1301p61913
http://www.aaronradiator.co.uk/products/Ra...-8380-1689.html
http://cgi.ebay.co.uk/TOYOTA-PASEO-1-5-16V...=item2562f54cfc
The Toyota part number is: 16400-11760 google gives nothing!
Are any of the above a solution?
Thanks
Mark
May help but when i was looking for a radiator for my manual N/A i gave a glanza chassis number and there were two prices one was £50 and the other was £150 i ordered the £50 one and got a standard replacement ideally i wanted the one with a thicker core which i can only assume was the £150 one
a genuine one will set you back £250~........my point being anything around the 50-70 mark will be a thin core one for the N/A and anthing £110+ should in theory be the bigger core which is what your after (auto obvs)
i would measure the thickness of core and double check with the above sellers ideally if you can, find a local motorfactor go down and check it out
yup i know, my point was that the prices stated on the websites indicate that they are bog standard thin core rads and he should be looking to pay atleast £100+ for one
Ok, so the Aaronradiator one is 27mm thick compared to camskills EP82 Turbo auto one which is 17mm I'd buy the Toyota OEM one if anyone has one new.
  snails ep91 said:
i have a second hand one you could buy off me if you like. perfect working condition comes with fan etc. few bent fins as expected. £40 + delivery. pm me if interested.
cheers
sam
Annoying as i was in Croydon yesterday. Don't need the fan, is it definately from an auto?
  • 4 weeks later...
